Problem With Redistribute Ospf into BGP with as-path prepend
Erico Verissimo
Hello all,
I have prefixes received by ospf and i wanna to redistribute into BGP, however, i need to get worse 50% of those prefixes using as-path prepend.
CISCO3945-CHASSIS
RT01_MPLS_OI_TRK(config-router-af)#redistribute static route-map redes_jbq_prepend
% "redes_jbq_prepend" used as redistribute static into bgp route-map, set as-path prepend not supported.
I have got the message above and i would know if there is an other way to get worse the prefixes.
Thanks for any support or suggestion.
Julio E. Moisa
Have you consider advertise the routes via BGP (using network command)  as they are already included into the routing table and matching and setting attributes using ip prefix-list and route-maps?
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
6 Replies 6
what are you trying to redistribute ? Static routes ? Post the config of what you have configured...
Following the config:
router ospf 100
router-id 10.206.4.13
log-adjacency-changes
auto-cost reference-bandwidth 100000
passive-interface GigabitEthernet0/2
network 10.206.4.0 0.0.0.255 area 0
network 192.168.151.76 0.0.0.3 area 0
network 192.168.151.112 0.0.0.3 area 0
router bgp 65115
bgp router-id 10.206.4.13
bgp log-neighbor-changes
neighbor 100.127.105.205 remote-as 7738
address-family ipv4
no synchronization
redistribute static
redistribute ospf 100 route-map OSPF_para_BGP
neighbor 100.127.105.205 activate
neighbor 100.127.105.205 soft-reconfiguration inbound
neighbor 100.127.105.205 filter-list 1 in
default-information originate
no auto-summary
exit-address-family
ip prefix-list anunciar_ao_BGP_JBQ seq 3 permit 0.0.0.0/0
ip prefix-list anunciar_ao_BGP_JBQ seq 4 permit 10.98.98.0/23
ip prefix-list anunciar_ao_BGP_JBQ seq 5 permit 10.98.0.0/28
ip prefix-list anunciar_ao_BGP_JBQ seq 7 permit 14.14.14.14/32
ip prefix-list anunciar_ao_BGP_JBQ seq 10 permit 10.99.5.224/27
ip prefix-list anunciar_ao_BGP_JBQ seq 11 permit 192.168.128.0/22
ip prefix-list anunciar_ao_BGP_JBQ seq 12 permit 192.168.134.0/28
ip prefix-list anunciar_ao_BGP_JBQ seq 15 permit 10.100.0.0/16
ip prefix-list anunciar_ao_BGP_JBQ seq 17 permit 10.123.0.0/24
ip prefix-list anunciar_ao_BGP_JBQ seq 20 permit 10.127.1.0/28
ip prefix-list anunciar_ao_BGP_JBQ seq 21 permit 10.127.4.0/23
ip prefix-list anunciar_ao_BGP_JBQ seq 26 permit 10.127.2.0/26
ip prefix-list anunciar_ao_BGP_JBQ seq 45 permit 10.254.0.0/24 le 27
ip prefix-list anunciar_ao_BGP_JBQ seq 55 permit 158.98.177.119/32
ip prefix-list anunciar_ao_BGP_JBQ seq 60 permit 158.98.183.171/32
ip prefix-list anunciar_ao_BGP_JBQ seq 65 permit 158.98.183.172/32
ip prefix-list anunciar_ao_BGP_JBQ seq 80 permit 192.168.200.0/24
ip prefix-list anunciar_ao_BGP_TRK seq 3 permit 0.0.0.0/0
ip prefix-list anunciar_ao_BGP_TRK seq 22 permit 10.127.6.0/23
ip prefix-list anunciar_ao_BGP_TRK seq 25 permit 10.127.1.16/28
ip prefix-list anunciar_ao_BGP_TRK seq 27 permit 10.129.25.0/24
ip prefix-list anunciar_ao_BGP_TRK seq 30 permit 10.206.0.0/16 le 24
ip prefix-list anunciar_ao_BGP_TRK seq 31 permit 10.206.2.0/27
ip prefix-list anunciar_ao_BGP_TRK seq 35 permit 10.208.0.0/16 le 24
ip prefix-list anunciar_ao_BGP_TRK seq 42 permit 172.16.85.0/24
ip prefix-list anunciar_ao_BGP_TRK seq 43 permit 172.16.88.0/24
ip prefix-list anunciar_ao_BGP_TRK seq 50 permit 129.73.116.88/29
ip prefix-list anunciar_ao_BGP_TRK seq 51 permit 172.16.37.0/24
ip prefix-list anunciar_ao_BGP_TRK seq 70 permit 192.68.48.0/22
ip prefix-list anunciar_ao_BGP_TRK seq 75 permit 194.138.39.16/29
ip prefix-list anunciar_ao_BGP_TRK seq 85 permit 150.2.0.0/16
ip prefix-list anunciar_ao_BGP_TRK seq 86 permit 10.128.101.0/24
route-map OSPF_para_BGP permit 10
match ip address prefix-list anunciar_ao_BGP_TRK
route-map OSPF_para_BGP permit 20
match ip address prefix-list anunciar_ao_BGP_JBQ
set as-path prepend 65115 65115 65115
On the other site i see, for example, the net 10.100.0.0 as below:
fm-rt01-samaritano_core#sh ip bgp 10.100.0.0
BGP routing table entry for 10.100.0.0/16, version 27206
Paths: (2 available, best #2, table default)
Not advertised to any peer
10429 65000
187.50.82.53 from 187.50.82.53 (186.200.157.65)
Origin incomplete, localpref 100, valid, external
Extended Community: RT:10429:4811
7738 65115
100.126.101.125 from 100.126.101.125 (200.195.97.10)
Origin incomplete, localpref 150, valid, external, best
AS Path prepend is used under route-maps for BGP purposes only for example to advertise a desirable path or not or for symmetric traffic to a BGP peer, for example you could use
route-map FILTERING-OUT permit 10
route-map FILTERING-OUT permit 20
Router  BGP 65114
address-family ipv4
no redistribute ospf 100 route-map OSPF_para_BGP
network 10.100.0.0 mask 255.255.0.0
neighbor 100.127.105.205 route-map FILTERING-OUT out
Georg...thank you for your attention ..
The problem was resolved.
Julio E. Moisa
Thank you Julio for the informations...
I think the problem it was resolved..
I kept the config:
Add the line:
neighbor 100.127.105.205 route-map redes_jbq_prepend out
//this line is linked to:
route-map redes_jbq_prepend permit 10
route-map redes_jbq_prepend permit 20
The last line (route-map redes_jbq_prepend permit 20) was able the rest of prefixes advertised by BGP with as-path prepend.
The result in other site was as below:
BGP routing table entry for 14.14.14.14/32, version 2959
Paths: (1 available, best #1, table default)
7738 65115 65115 65115 65115
100.127.83.253 from 100.127.83.253 (200.195.97.10)
Thanks..
Origin incomplete, localpref 100, valid, external, best
