Problem with routing on Packet Tracer
Hi I just started to use Packet Tracer and learn how to add routes in Routing Table:
I want to do the following topoly:
topologytopology
These are my router table from router1:
Spoiler
192.168.1.0/28 is subnetted, 1 subnets
C 192.168.1.0 is directly connected, FastEthernet0/0
192.168.2.0/30 is subnetted, 1 subnets
C 192.168.2.0 is directly connected, Serial0/0/0
192.168.3.0/28 is subnetted, 1 subnets
S 192.168.3.0 [1/0] via 192.168.2.2
192.168.4.0/30 is subnetted, 1 subnets
S 192.168.4.0 [1/0] via 192.168.2.2
192.168.5.0/30 is subnetted, 1 subnets
S 192.168.5.0 [1/0] via 192.168.6.2
192.168.6.0/30 is subnetted, 1 subnets
C 192.168.6.0 is directly connected, Serial0/0/1
These are from router 2:
Spoiler
S 192.168.1.0 [1/0] via 192.168.2.1
C 192.168.3.0 is directly connected, FastEthernet0/0
C 192.168.4.0 is directly connected, Serial0/0/1
192.168.5.0/28 is subnetted, 1 subnets
S 192.168.5.0 [1/0] via 192.168.4.1
S 192.168.6.0 [1/0] via 192.168.4.1
These are from router 3:
Spoiler
S 192.168.1.0 [1/0] via 192.168.6.1
S 192.168.2.0 [1/0] via 192.168.4.2
C 192.168.5.0 is directly connected, FastEthernet0/0
C 192.168.6.0 is directly connected, Serial0/0/0
Although I can ping from PC1 to 192.168.1.1, from PC2 to 192.168.3.1 and from PC3 to 192.168.5.1 I can't from PC1 to 192.168.2.2 and general can't ping from any pc to other pc's or routers through the serial interface.
Any suggestion?
7 Replies 7
luis_cordova
Hi @KonstantinosDimos78791
First, make this change in R3
no ip route 192.168.3.0 255.255.255.240 192.168.2.2
ip route 192.168.3.0 255.255.255.240 192.168.4.2
You must ensure that all PCs have the correct gateway:
PC1
IP192.168.1.10
Mask 255.255.255.240
Gateway 192.168.1.1
PC2
IP192.168.3.10
Gateway 192.168.3.1
PC3
IP192.168.5.10
Gateway 192.168.5.1
Thanks you are right!
Now I want to declare a floating route from R1->Lan3(PC3) through R2 and test the connection when R1,R3 connection is down.I made something but I want to compare!!!
Thanks in advance!
Floating routes differ from normal static routes only by adding the indicated cost at the end of the command.
Static routes have a cost of 1 by default, so assigning a cost greater than 1 would already be that floating route.
In your case:
R1
ip route 192.168.5.0 255.255.255.240 192.168.2.2 2
R2
ip route 192.168.5.0 255.255.255.240 192.168.4.1 2
ip route 192.168.1.0 255.255.255.240 192.168.2.1 2
R3
ip route 192.168.1.0 255.255.255.240 192.168.4.2 2
Remember to mark the correct answer as solved, because that helps other users with similar questions
Hi again , I have a little problem configuring the following topolgy with RIPV1:
topologytopology
These are the data from ip route of router 1:
Gateway of last resort is not set
C 192.168.1.0/24 is directly connected, FastEthernet0/0
C 192.168.2.0/24 is directly connected, Serial0/0/0
C 192.168.6.0/24 is directly connected, Serial0/0/1
These are the data from ip route of router 2:
C 192.168.3.0/24 is directly connected, FastEthernet0/0
C 192.168.4.0/24 is directly connected, Serial0/0/1
These are the data from ip route of router 3:
C 192.168.5.0/24 is directly connected, FastEthernet0/0
C 192.168.6.0/24 is directly connected, Serial0/0/0
The routers are able to ping each other and to their FastEthernet interfaces.
These are the instructions for router 1 to configure RIPV1:
Router1(config)#router rip
Router1(config-router)#version 1
Router1(config-router)#no auto-summary
Router1(config-router)#network 192.168.3.0
Router1(config-router)#network 192.168.4.0
Router1(config-router)#network 192.168.5.0
Router1(config-router)#end
But again I take the same records:
Any suggestion?
post the zipped .pkt (Packet Tracer project file) here...
hi @KonstantinosDimos78791
In routing protocols, using the network command, you must indicate the interfaces (networks) that will participate in the protocol. Therefore, the networks indicated on each router must be those that are directly connected to that router.
Try this:
Router1(config-router)#network 192.168.1.0
Router1(config-router)#network 192.168.2.0
Router1(config-router)#network 192.168.6.0
Router2(config)#router rip
Router2(config-router)#version 1
Router2(config-router)#no auto-summary
Router2(config-router)#network 192.168.2.0
Router2(config-router)#network 192.168.3.0
Router2(config-router)#network 192.168.4.0
Router2(config-router)#end
Router3(config)#router rip
Router3(config-router)#version 1
Router3(config-router)#no auto-summary
Router3(config-router)#network 192.168.4.0
Router3(config-router)#network 192.168.5.0
Router3(config-router)#network 192.168.6.0
Router3(config-router)#end
