Problem with VLAN cisco 881
Vermes000
We are using cisco 881 router and managed to configure internet connection for router and a switchport with vlan (plus DHCP) but we can't find a way to have internet on the vlan.
Ping from router to internet is OK
Ping from computer 1 to computer 2 in vlan is OK
Ping from router to vlan is not ok...
Out configuration is attached.
Thanks for help
10 Replies 10
cadet alain
It's surely a NAT problem but you omitted to attach the config.
do these commands and post them here:
show ip nat stat
show  run | i nat|access-list
Alain
show ip nat stat
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 22, occurred 06:43:08 ago
Outside interfaces:
  FastEthernet4
Inside interfaces:
  Vlan1
Hits: 355  Misses: 0
CEF Translated packets: 257, CEF Punted packets: 57
Expired translations: 56
Dynamic mappings:
-- Inside Source
[Id: 2] access-list 2 interface FastEthernet4 refcount 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
show run | i nat |access-list
 ip nat outside
 ip nat inside
ip nat inside source list 2 interface FastEthernet4 overload
ip access-list extended AAAccess
access-list 1 permit any
access-list 1 permit 0.0.0.0 255.255.255.0
access-list 100 permit tcp any any
access-list 2 permit 192.168.1.0 0.0.0.255
Alain
Tried this but it doesn't work.
I'm trying for test:
ping google.pl source 192.168.1.1
Strange this is that if I ping from a DHCP (VLAN) computer ping for example google, amazon etc.I see it's IP address but no packets are back.
you should ping an external IP like 8.8.8.8 to test.
if the test on the router is working then try the same from a PC and if it is ok then do the test on the PC by pinging the name and if it fails then it is a DNS problem.
Alain
Yeah, sure I know. I've tested earlier 8.8.8.8 and it's not ok, and after that tested google.pl and had this small observation that ip address is correctly translated when using a domain name.
post sh ip nat tr after pinging 8.8.8.8   to see if NAT is working.
Also remove any ACL from the interfaces, I can't see your config anymore so could you post it in the reply body please.
Alain
Tried to attach it several times but always an error. Config below
version 15.3
no service pad
hostname XXX
boot-start-marker
boot-end-marker
enable secret 5 AAA
enable password BBB
no aaa new-model
memory-size iomem 10
ip dhcp excluded-address 192.168.0.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool AA
 network 192.168.1.0 255.255.255.0
 dns-server 192.168.1.1
 default-router 192.168.1.1
ip host ServerGP 223.12.197.123
ip name-server 223.12.192.22
ip name-server 211.121.88.88
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn 11111
interface Loopback0
 no ip address
interface Loopback1
 no ip address
interface FastEthernet0
 switchport mode trunk
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
 ip address 223.12.197.126 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex full
 speed auto
interface Vlan1
 ip access-group AAAccess in
 ip access-group AAAccess out
 ip nat inside
ip default-gateway 223.12.197.121
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 223.12.197.121
ip access-list extended GPAccess
 permit ip any any
snmp-server community public RO
line con 0
 no modem enable
line aux 0
line vty 0 4
 password aaa
 login
 transport input all
end
 why didn't you post updated config with ACL 2 ?
Anyway what does sh ip nat tr outputs when pinging 8.8.8.8 sourcing from vlan1 ?
if it is empty then do some debugs:
conf t
logging buff 7
do debug ip nat
do ping 8.8.8.8 so Vlan1
do sh log
Then post output
Alain
hi
Either  change  ip nat inside source list 1 interface FastEthernet4 overload
or create access-list 2  permit 192.168.1.0 0.0.0.255
and also change ip route 0.0.0.0 0.0.0.0 Fastethernet4. for safe side.
T.Khan
