Problem with VWIC
lebaphuong
I have VWIC 2MFT-G703. When I switch power on (router 3660), all AL LED turn yellow. Is this card all right?. What I have to do?
spremkumar
Level 9
Level 9
Have you tried reinstalling the same in another available slot ?
Also are you seeing any error logs there in the console ? can you post the output of sho version taken out from the router ?
regds
I tried reinstalling in another slot and result is the same (all AL LEDs are amber)
I don't see any error logs in the console
Here is Version taken from the router
IOS (tm) 3600 Software (C3660-JS-M), Version 12.1(5)YB2, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 21-Mar-01 03:44 by ealyon
Image text-base: 0x60008960, data-base: 0x61680000
ROM: System Bootstrap, Version 12.0(6r)T, RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3660-JS-M), Version 12.1(5)YB2, EARLY DEPLOYMENT RELEASE SO
FTWARE (fc1)
VTI-HCM-SPT uptime is 13 minutes
System image file is "flash:c3660-js-mz_121-5_YB2.bin"
cisco c3660 (R527x) processor (revision C0) with 56320K/9216K bytes of memory.
Processor board ID JAB053580MB
R527x CPU at 225Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
3660 Chassis type: ENTERPRISE
4 FastEthernet/IEEE 802.3 interface(s)
4 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Best Regards
Phuong
