Problems upgrading 897VA-M
rasmus.elmholt
Level 11
Level 11
Hi there
I have just tried upgrading a 897 router but now it is unable to boot into the IOS. I can get to rommon, but I am not able to load any IOS from the flash or an usb pen.
It just hangs after the boot message.
This is a brand new router.
System Bootstrap, Version 15.2(3r)XC, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 512 MB
C897VA-M-K9 platform with 524288 Kbytes of main memory
Main memory is configured to 32 bit mode
Readonly ROMMON initialized
monitor: command
monitor: command "
monitor: command "boot" aborted due to user interrupt
rommon 1 >
rommon 1 > dir
usage: dir <device>
rommon 2 >  flash:
monitor: command "flash:" not found
rommon 3 > dir flash:
program load complete, entry point: 0x4000000, size: 0x18c40
Directory of flash:
17668    68540516  -rw-     c800-universalk9-mz.SPA.153-3.M10.bin
13     0         drw-     syslog
17650    0         drw-     managed
rommon 4 > del
monitor: command "del" not found
rommon 5 > delete
monitor: command "delete" not found
rommon 6 > ?
alias               set and display aliases command
boot                boot up an external process
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
context             display the context of a loaded image
cookie              display contents of motherboard cookie PROM in hex
dev                 list the device table
dir                 list files in file system
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
iomemset            set IO memory percent
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
rommon-pref         Select ROMMON
set                 display the monitor variables
showmon             display currently selected ROM monitor
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tftpdnld            tftp image download
unalias             unset an alias
unset               unset a monitor variable
rommon 7 > history
1   dir
2    flash:
3   dir flash:
4   del
5   delete
6   ?
7   history
rommon 8 > history 4
1   dir
2    flash:
3   dir flash:
4   del
5   delete
6   ?
7   history
8   history 4
rommon 9 > dir usbflash0:
program load complete, entry point: 0x4000000, size: 0x3d920
Directory of usbflash0:
rommon 10 >       " not found
rommon 11 > dir usbflash0:
6      96100236  -rw-     c800-universalk9-mz.SPA.157-3.M3.bin
5872    68515484  -rw-     c800-universalk9-mz.SPA.153-3.M6.bin
rommon 12 > boot usbflash0:c800-universalk9-mz.SPA.153-3.M6.bin
IOS Image Load Test
___________________
Digitally Signed Production Software
program load complete, entry point: 0x4000000, size: 0x4157390
Self decompressing the image : #################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
*** No sreloc section
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
    Onboard devices &
         buffer pools      0x022ECEC0
               TOTAL:      0x022ECEC0
Rounded IOMEM up to: 34Mb.
Using 6 percent iomem. [34Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 04-Aug-15 05:50 by prod_rel_team
It just hangs here every time. I have triede different IOS versions.
0 Replies 0
