05-27-2025 04:05 AM
Hi all. Im about to set up an PLC from siemens, that uses Profinet protocol.
It use a none standart protokol, wich has a bigger framsize.
normaly on our other switches and routers, i just make it a Trunkport, wich allow trafick on the specefik vlan:
switchport access vlan xxx
switchport trunk native vlan xxx
switchport trunk allowed vlan xxx
switchport mode trunk
but that dont seeam to work here. i can se on the intereface, that i have unknows protocols drops counting up.
I did also try make it a voice port, to support the larger frame:
switchport mode access
switchport voice vlan dot1p
but that aint working eighter.
does anyone have som surggenstion
thx!
05-27-2025 11:19 AM
You are confusing switches and routers.
Routers don't have trunk ports, but do support dot1q subinterfaces to connect to switcheports configured for dot1q trunks.
What type of device + os are you trying to configure
05-28-2025 12:04 AM
hhmm its an 1101 Industrial Integrated Services Router.
05-28-2025 01:30 AM - edited 05-28-2025 01:36 AM
switchport access vlan xxx <---- this command has no use on a port configured as a trunk
1) making it a "voice port" does not enable larger frames? voice packets contain only 64 bytes payload!
you may need to enlarge the MTU-size instead
2) what interface are you configuring? the IR1101 ports are FE? (=100Mbps) and what kind of port does your PLC have?
3) doing a quick search I found no reference to profinet support in the IR1101's specs,
you can use the feature navigator https://cfnng.cisco.com/browse/iot/routers to search yourself
