PT static route through multilayer switch
wimpeld
Hello everyone!
I'm new here, and this is my first (and from the looks of it very likely not my last) post.
I'm currently unable to figure out how to ping from "Router 1" to "Router 2".
I tried several things using IP route but whatever I try, it seems to not go past the multilayer switch.
Yes I have to absolutely use these devices as is, as that is part of my assignment.
If anyone could explain or just show me why this isn't working out, I'd be forever grateful. :)
Hello
Both R1 -R2 and its internal hosts can now ping each R1-R2 inside global address.
You had multiple configuration mistakes, including conflicting static routes on R1-R2, CM1-Cm2 and  incorrect static nat statements ( 198. - instead of 192.) on R1-R2
Lastly missing ip addressing on server-PT 192.168.0.201 and it associated link on the Multi-layer switch.
Please review amended PT
Kind Regards
Paul
you need to enable 'ip routing' on the multilayer switch:
Switch(config)#ip routing
Hello
Kind Regards
Paul
Odd, that's what I did at first and it didn't work. I can only assume I did something something wrong and from there on spiralled down-hill trying to figure out what. Shows I have still a ways to go. :)
I am aware of not everything being configured yet because my primary concern was that I couldn't ping from router 1 to router 2!
Anyway, your reply has brought clarity on the matter at hand and what I should do different from here on.
Thank you!
