Public lan ip assigning for a internal network server
midhunlaln66
Hi all,
In our networking lab we purchased public lan ip from my provider (ISP)and they advertised lan ip in our network. Now i am planning to assign one public ip to a server which is available in my lab.I need to access this server from outside (publicly).How I can achieve this.
Airtel->asa firewall->asr router->core sw->lan.
This is the traffic flow in lab.what changes i need to do in firewall and router.plz support me.
Thanks in advance.
Hello
You will need to perfrom Network/Port AddressTranslation (NAT/PAT) either on the Firewall or RTR depending on which device you manage.
ASA example PAT https
object network LanHost
host 192.168.1.10
nat (inside,outside) static 1.1.1.1 service tcp 443 443
access-list 100 exteneded permit tcp any object LanHost eq 443
RTR example PAT https
ip nat inside source static tcp 192.168.1.10 443  1.1.1.1 443
Kind Regards
Paul
