Change the lease times
Hi, I am struggling to change the lease times on a router (and also in packet tracer)
The command lease 5 30 5 (as an example) just gives an bad command prompt
The aim here is an high turnover area of clients in an address pool I want to purge or renew leases every few hours.
Any thoughts?
5 Replies 5
what is your time expecting to set?
format is  lease days [hours] [minutes]
for ex. lease 5 20 5
in your command there is issue in hours. you can maximum go up to 23 in hours. and you cannot use 30 there.
Good luck
KB
Router(config)#lease 12 5 30
% Invalid input detected at '^' marker.
Still cannot use the command?
what is the model of Router and IOS Code running on it ?
what is the option = lease ? ( what options you have ?)
BB
how much time you need to set as lease time?
are you trying in packet tracer? packet tracer not support this command
Good luck
KB
 In PacketTracer dont seems to be possible. Real router IOS is possible but you need to be inside the DHCP pool:
R1(dhcp-config)#le
R1(dhcp-config)#lease ?
<0-365> Days
infinite Infinite lease
