Purpose of Package
i need to free up my 2811 router memory.
so if i remove this package, it will cause impact or i will miss any functionality ?
  -rw-     1697952   Mar 4 2008 16:03:58 +00:00  securedesktop-ios-3.1.1.45-k9.pkg
John Blakley
Secure Desktop, I believe, is used in conjunction with SSL VPN and managing clients. If you're not using that, you can safely delete it.
HTH,
John
HTH, John *** Please rate all useful posts ***
you may need to squeeze the flash to totally remove it.
router#squeeze bootflash:
another way to save space it to compress the running config.
router(config)service compress-config
res
Paul
Kind Regards
Paul
