PWR-2700-AC/4= and PWR-2700-AC=
Patrick Harrold
Hi All,
It seems there is some confusion over these two power supplies. Are they the exact same? On first blush I would expect they would be different but I'm not so sure now.
We purchased a new 7606-S from CDW some time ago and it came with a PWR-2700-AC/4= power supply. However, the Cisco data sheet for the 7606-S only lists the PWR-2700-AC= power supply as an option. Not the PWR-2700-AC/4=
  (http://www.cisco.com/en/US/prod/collateral/routers/ps368/ps371/product_data_sheet0900aecd8057f3c8.html). Apparently CDW only sells "validated" Cisco configurations...
Can somebody clear this up? Are these two model numbers the same? If not, what is the difference?
PWR-2700-AC/4=
PWR-2700-AC=
Note, we've had our 7606-S running with x2 of these power supplies: PWR-2700-AC/4=. One of them recently broke and continue to trip the PDU circuit whenever it is plugged in. I suspect it's because the power supply is the incorrect model number...
Ivan Shirshin
Hi Patrick,
PWR-2700-AC is for 7606, PWR-2700-AC/4 is for 7604.
PWR-2700-AC for 7606 has bigger front panel than that for the PWR-2700-AC/4 for 7604.
They are not interchangeable.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Hi Patrick,
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hi Ivan,
Thanks for the reply and the info on the front panel size. I gathered as much from the various spec sheets I read. These two power supplies were never listed together for any chassis.
Patrick
welcome, Patrick!
Kind Regards,
Ivan
Ivan, I have a emergency situation.   An AC Power hit took out our PWR-2700-AC.    I have an extra PWR-2700-AC/4.   If I mechanically swap out the front mounting panel, will the PWR-2700-AC/4 work as a temporary replacement for the PWR-2700-AC.   They both use the ASTEC Model AA23420  model power supply.
Carl
