03-23-2023 12:45 AM - edited 03-23-2023 12:54 AM
hi,
will be doing QinQ on a cisco 4k router.
saw this feature was added on IOS-XE 16.12.1
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/layer2/configuration/xe-16-12/layer2-tunneling-config-book/layer2-config-16-12-book_chapter_00.html
but it's only available using NIM-ES module.
https://www.cisco.com/c/en/us/td/docs/routers/access/isr4400/software/configuration/xe-17/isr4400-sw-config-xe-17/configuring_ethernet_switchports.html#Cisco_Concept.dita_3d413e66-182b-4f7e-a1ec-c15cda4fbb44
is there an option for fiber port?
will QinQ work on a NIM 1GE-CU-SFP or 2GE-CU-SFP? or is this only a WAN module?
Log in to Community
