QOS - Dropped packets
rll3
Does anyone know of a way to count or log DROPPED Packets?
5 Replies 5
izackvail
Can you be more specific? With CB you can use the command:
show policy-map interface
with the Sh policy-map int command it only shows that there were some drops, and the packets being queued are showed at the time of queueing, but what I would like to be able to see is the actual dropped packet.
Like is there a way I could be notified when a packet is dropped?
There are some snmp mibs that will allow you to monitor qos but I don't know of any native ios function that will alert you when qos causes a packet drop. Anyone else?
I not able to use a sniffer, but I'm not sure that it will tell me what packets didn't make it.
