QOS for specific IPs
hi,
I am trying to give priority to some IPs from the internet, currently we have 7 ips that are pushing data to our network.
So if we want to give this data priority over other data, will below steps work? please suggest
1: enable qos globally using mls qos
2: create a access list to catch those specific ips
3: create a class map
4: create a policy map and attach it to a ip precedence of 5
5: create a service policy and apply it inside of the interface.
we are not looking to police this data , just wanted to make sure the traffic from these IPs are preferred on top of all other traffic.
thanks
Viveknath
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You'll be doing this on a Catalyst switch?
What I believe you've described will mark the selected traffic switch with IPPrec 5, but such a marking, alone, does not guarantee such traffic will be preferred on the network.  This devices, and any downstream devices, would also need to be configured to treat IPPrec marked traffic "better".
BTW, IPPrec 5 is often used only for real-time traffic.  If this is not real-time traffic, you might want to use a lower IPPrec value (which doesn't preclude still treating such marked traffic "better".)
You might consider:
IPPrec 5 real-time (e.g. VoIP)
IPPrec 4 video
IPPrec 3 VoIP signally
IPPrec 2 critical data
IPPrec 0 default
IPPrec 1 scavenger
hi,
this is a real time traffic and we will be doing this activity on a cisco catalyst 3560.
after marking the traffic with ip precedence 5, is there any steps that we need to do to give this traffic priority ?
or is there a way to give these IP ( 7 of them ) dedicated bandwidth of 22Mbps?
thanks in advance for helping us out.
regards
Vick
