QOS help and dropped packets
roadracers
I am trying out a new QOS map and ran into dropped packets on our second site. The first site I implemented this on is working with no packet loss. The second site has two routers and both are randomly dropping packets. All sites are running Cisco 3925 routers with DS3 encap PPP circuits. First site has one router and the other has two routers. The packet loss does not seem to be service affecting, but we shouldn't be seeing any packet loss, as the circuits haven't gone over 20% utilization.
Any comments or suggestions would be greatly appreciated. Below is the config added and show policy-map:
class-map match-any AF4x
match ip dscp af41
class-map match-any AF3x
match ip dscp af31
class-map match-any AF2x
match ip dscp af21
class-map match-any Voice
match ip dscp ef
class-map match-any Scavenger
match ip dscp cs1
class-map match-any AFclass
match ip dscp af21  af31  af41
policy-map AFsubclass
class AF4x
   police rate percent 20
     exceed-action set-dscp-transmit af42
class AF3x
   police rate percent 5
     exceed-action set-dscp-transmit af32
class AF2x
     exceed-action set-dscp-transmit af22
policy-map STDqos
class Voice
  priority percent 10
class AFclass
  bandwidth percent 25
  service-policy AFsubclass
class Scavenger
   police rate percent 4
     exceed-action set-dscp-transmit default
     violate-action drop
class class-default
  bandwidth percent 50
  random-detect dscp-based
policy-map Shape
class class-default
  shape average 44210000
  service-policy STDqos
interface Serial1/0
service-policy output Shape
sh policy-map int s 1/0  | inc Class|offered|drops
    Class-map: class-default (match-any)
      30 second offered rate 5141000 bps, drop rate 0 bps
      (queue depth/total drops/no-buffer drops) 0/123/0
          (queue depth/total drops/no-buffer drops) 0/35/0
        Class-map: Voice (match-any)
          30 second offered rate 4611000 bps, drop rate 0 bps
          Priority: 10% (4421 kbps), burst bytes 110500, b/w exceed drops: 0
        Class-map: AFclass (match-any)
          30 second offered rate 0 bps, drop rate 0 bps
          (queue depth/total drops/no-buffer drops) 0/0/0
            Class-map: AF4x (match-any)
            Class-map: AF3x (match-any)
            Class-map: AF2x (match-any)
        Class-map: Scavenger (match-any)
          30 second offered rate 527000 bps, drop rate 0 bps
          (queue depth/total drops/no-buffer drops) 0/53/0
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
It's possible drops are due to microbursts and insufficient queue depths.
