QoS in DMVPN cloud doesn't work with ISR4451-X as a hub
Ivan Rezvantsev
Good day.
We have configured QoS in DMVPN with this guide:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dmvpn/configuration/15-mt/sec-conn-dmvpn-15-mt-book/sec-conn-dmvpn-per-tunnel-qos.html
It is working well in test lab stand with cisco 881 or cisco 2901 as a hub and 881 and 2901 as a spokes with this ios:
c880data-universalk9-mz.152-4.M1.bin
c2900-universalk9-mz.SPA.152-4.M2.bin
But not with 4451-X as a hub.
In real world we have  ISR4451-X/K9  (isr4400-universalk9.03.16.01a.S.155-3.S1a-ext.SPA.bi) as a hub and spokes 881 and 2901 as listed above. And I see something strange. hub tunnel interface:
interface Tunnel5
description DMVPN_tunnels
ip address 172.19.0.1 255.255.252.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 100
ip nhrp authentication cisco
ip nhrp map multicast dynamic
ip nhrp network-id 10101
ip nhrp holdtime 300
ip tcp adjust-mss 1360
delay 1000
nhrp map group 10M-TESTING service-policy output 10M-TESTING
nhrp map group 15M-TESTING service-policy output 15M-TESTING
nhrp map group 20M-TESTING service-policy output 20M-TESTING
nhrp map group 3M-TESTING service-policy output 3M-TESTING
tunnel source Port-channel2
tunnel mode gre multipoint
tunnel key 100
tunnel path-mtu-discovery
tunnel protection ipsec profile dmvpn shared
show dmvpn detail shows that all correct:
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb Target Network
1 XXX.XXX.XXX.XXX 172.19.0.2 UP 05:41:18 D 172.19.0.2/32
NHRP group: 3M-TESTING
Output QoS service-policy applied: 3M-TESTING
1 XXX.XXX.XXX.XXX 172.19.0.19 UP 1w1d D 172.19.0.19/32
NHRP group: 20M-TESTING
Output QoS service-policy applied: 20M-TESTING
1 XXX.XXX.XXX.XXX 172.19.0.23 UP 1d02h D 172.19.0.23/32
1 XXX.XXX.XXX.XXX 172.19.0.24 UP 1w2d D 172.19.0.24/32
NHRP group: 15M-TESTING
Output QoS service-policy applied: 15M-TESTING
but show nhrp group-map shows that there is no policy applied:
Interface: Tunnel5
NHRP group: 10M-TESTING
QoS policy: 10M-TESTING
Transport endpoints using the qos policy: None
QoS policy: 15M-TESTING
QoS policy: 20M-TESTING
QoS policy: 3M-TESTING
and show policy-map multipoint tunnel 5 shows nothing.
And on the traffic monitor I see that polices are not working.
For example spoke config from 881:
interface Tunnel5
description DMVPN
ip address 172.19.0.2 255.255.252.0
no ip redirects
ip mtu 1400
ip nhrp group 3M-TESTING
ip nhrp map multicast XXX.XXX.XXX.XXX
ip nhrp map 172.19.0.1 XXX.XXX.XXX.XXX
ip nhrp nhs 172.19.0.1
delay 1000
tunnel source FastEthernet4
tunnel key 100
tunnel protection ipsec profile one shared
Any ideas why this happens? And what I need to do to make qos work with 4451-X as hub?
Philip D'Ath
You are a couple of releases out in your software train on the 4451.  I would upgrade to a gold star release like 3.16.3S before investing too much time in figuring out the issue.
https://software.cisco.com/download/release.html?mdfid=284389362&softwareid=282046477&release=3.16.3S&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Philip D'Ath
Interestingly, the release notes make special mention of this guide for Tunnel QoS.  Note this is a specific IOS-XE guide, as compared to the IOS guide you posted above.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dmvpn/configuration/xe-3s/sec-conn-dmvpn-xe-3s-book/sec-conn-dmvpn-per-tunnel-qos.html
I intalled new IOS you recommended. But the problem not the IOS I saw in the guide:
The Per-Tunnel QoS for DMVPN feature does not support the following:
  • Per-Tunnel QoS for IPv4 or IPv6 or Multiprotocol Label Switching (MPLS) VPN over DMVPN with Layer 2 Tunnel Protocol (L2TP) transport.
  • Per-Tunnel QoS for IPv4 or IPv6 or MPLS VPN over DMVPN on a port-channel interface or aggregate port-channel interface.
It does not support port-channel source interface. And it is extremly bad.
Any ideas how to make qos in such DMVPN enviroment ? We have many voip and video which is poor quality because DMVPN cloud made on low quality Internet links.
The only other option I can think of is to do to it radically differently.  Use the tunnel "qos pre-classify" option, and then performance QoS on the physical interface that all the tunnels run out of.  Note this will do it for the entire circuit then, and not per "connection".
Not as good, but much better than nothing.
