Allocation Bandwidth for BFD
bibek_deo
HI,
I am using  "BFD" ( Bidirectional Failure Detect ) for BGP.It has been  observed the BFD goes down when the link is utilized hence breaking the connectivity between BGP  peer , I Want to configure some BW for BFD , so can someone suggest me how can I do that
Bibek
prabhurraj
Try using a low latency queuing on that interface and define the UDP port 3784 to get a bandwidth percent allocated during congestion.
http://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/fsllq26.html#wp1019777
