QoS on C887VA: SIP, DSCP and LLQ
francois_vaning
Hello Cisco Support Community ;)
I have a question about LLQ QoS configuration specifically about DSCP usage.
I'm trying to enable QoS egress on an VDSL line.
My config looks like this:
class-map match-all Voice
 match ip dscp ef
class-map match-any CallSignaling
 match ip dscp cs3
 match ip dscp af31
policy-map WAN-EDGE
 class Voice
  priority percent 33
 class CallSignaling
  bandwidth percent 5
 class class-default
  fair-queue
interface Dialer1
 mtu 1492
 bandwidth 22500
 ip address negotiated
 no ip redirects
 no ip unreachables
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 load-interval 30
 dialer pool 1
 dialer-group 1
 ppp authentication chap callin
 ppp chap hostname woot
 ppp chap password 0 woot
 ppp direction callout
 ppp pap sent-username woot password 0 woot
 ppp ipcp header-compression ack
 ppp ipcp dns request accept
 ppp ipcp address accept
 service-policy output WAN-EDGE
This config is nearly entirely based on a QoS design document edited by Cisco (http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book.html)
When analysing packets using packet capture on the router I can see packets with DSCP code af31 (HexTOS 0x68).
However, when issuing sh policy-map interface dialer 1 here is what I get:
R887-H#sh policy-map interface dialer 1
 Dialer1
  Service-policy output: WAN-EDGE
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: Voice (match-all)
      715 packets, 68700 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match: ip dscp ef (46)
      Priority: 33% (7425 kbps), burst bytes 185600, b/w exceed drops: 0
    Class-map: CallSignaling (match-any)
      0 packets, 0 bytes
      Match: ip dscp cs3 (24)
        0 packets, 0 bytes
        30 second rate 0 bps
      Match: ip dscp af31 (26)
        0 packets, 0 bytes
      Queueing
      bandwidth 5% (1125 kbps)
    Class-map: class-default (match-any)
      137497 packets, 17237719 bytes
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      Fair-queue: per-flow queue limit 16 packets
For some reason it looks like the dscp code is not matched...
I don't understand why. Furthermore, i've also tried multiple configurations to match those packets:
- match protocol sip
- ACL created to matche this traffic.
- putting both af31 and cs3 as af31 seems to be the legacy.
- putting priority 100 for both classes (as a percent of 22000 kbps is still a huge number)
I don't know if it's related but voip works perfectly downstream (hearing the other people) but slightly bad on upstream (other people hearing what you're saying).
Any help would be welcome ;)
BTW, i'm using Version 15.2(4)M5 on C887VA
Thanks a lot!
François Van Ingelgom
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
At a glance, what you have looks correct, so I wonder whether you might be hitting a bug.
However, I also wonder whether NAT is causing the match statement to fail.
Since your traffic is actually using AF31, you might try matching only for that.
Or, you might try matching both CS3 and AF31 with the same match statement.
Or, you might try matching just for IPPrec 3 (if you don't have AF32 or AF33 traffic).
Thanks for your answer!
I will investigate the potential NAT issue. From what i can see in my captures, packet might be natted but it still have the correct dscp flags on it.
I've tested with:
- match ip dscp af31
match ip dscp af31 cs3
- match ip precedence 3
Still the same results... I also wonder if i might be hitting a bug on IOS. Unfortunately, I don't have a subscription on this device so .... I guess i'm stuck :(
Still it works for rtp which is probably the most important but i'm concerned about having unresponsive calls in case of congestion due to the inability to signal the end of the call...
Anyway, thanks a lot for your help!
François
Disclaimer
Posting
If the FQ in class-default works as it should, your signalling traffic shouldn't be much at risk.  In fact, IMO, just FQ alone deals effectively with about 90% of all QoS requirements.  Adding a real-time class, deals with about 99% of all QoS requirements, and the following policy, deals with almost 100%.
policy-map sample
class real-time
priority percent 33
class hi-priority
bandwidth remaining percent 89
fair-queue
class lo-priority
bandwidth remaining percent 1
fair-queue
class class-default
bandwidth remaining percent 9
fair-queue
Usage of the above's non-LLQ classes should ideally be the inverse of the class percentages.  The class percentages are set, in the above, not for bandwidth reservations, but for relative dequeuing priorities.
Also in the above, almost all non-LLQ traffic should be in the default class.  Lo-priority is useful for known bandwidth hogs that are bandwidth adaptable (e.g. most TCP) and aren't timing sensitive.  An example might be bulk file copies.  Hi-priority is for flows that really, really need priority over others, but don't have a real-time requirement.  A good example of such traffic might be "screen scraping", like Citrix or RDP.  Or, possibly something like telnet.
The above, also can work really well if you can dynamically move flows between classes based on flow's bandwidth usage.
Thank you for providing me this sample, i've used it ;)
Now everything seems to be working aok, calls are not disturbed anymore.
For the record, I think i've found why I had uplink performance issue:
I use nbar for firewalling and I didn't tell it to inspect sip just tcp and udp.
I think that now that I have instructed it to inspect sip, the laggy output issues are gone. (hopefuly).
I'll try to update the IOS software if we have a subscription some days...
François
I'll throw in the suggestion that what you are trying to do is technically not supported on the version of IOS you have installed.
You'll want to go to 15.3(3)M(latest) which is now MD, or 15.4(3)M(latest) for this to be officially supported:
Refer:
Shaping on Dialer Interfaces   15.3(1)T        The Shaping on Dialer Interfaces feature provides support for PPPoE/A configurations on dialer interfaces.
From: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/qos_conavd/configuration/15-mt/qos-conavd-15-mt-book/qos-conavd-dial.html#GUID-F0B9C4C2-6852-4CC3-B671-C61B77BC6A24
Hello all!
As sugested, i've upgraded to 15.3(3)M4.
I now have QoS working for both rtp packet and sip packet.
However I had to configure very differently because this configuration didn't work in 15.3(3)M4.
It gave me the following error:
Flow Fair Queueing feature is not supported in default class of parent level policy of
As suggested in this thread: https://supportforums.cisco.com/discussion/12351281/applying-service-policy-output-dialer-interface-887va
I converted my configuration this way:
policy-map childpol
 class Voice
  priority 200
 class CallSignaling
  bandwidth 200
 class class-default
  fair-queue
policy-map parpol
 class class-default
  shape average 16800000
   service-policy childpol
It seems to be working now, however I'm concerned the traffic might get first shaped then prioritized adding latency to the process because of the shaping first occuring.
I am wrong? If not, what could be a better configuration?
Thanks a lot for your help!
Disclaimer
Posting
In theory, the shaper should use the child policy queues, but Cisco doesn't document exactly how things work, and from past experience, I suspected some Cisco version had both shaper and child policy queues.
I doubt the shaper would be an issue for any traffic except perhaps for the child's LLQ, so what you might do is:
policy-map childpol
 class CallSignaling
  bandwidth 200
 class class-default
  fair-queue
policy-map parpol
class Voice
  priority 200
  police average 200000
 class class-default
  shape average 16600000
I'll try this config today!
I also suspect Cisco use two queues in this config because when I issue this command:
R887-H#sh policy-map int dial 1
 Dialer1
  Service-policy output: parpol
      Queueing
      (pkts output/bytes output) 3/306
      3251500 packets, 321841076 bytes
      30 second offered rate 4000 bps, drop rate 0000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/3/0
      (pkts output/bytes output) 3251398/322104458
      shape (average) cir 16800000, bc 67200, be 67200
      target shape rate 16800000
      Service-policy : childpol
          Queueing
          (pkts output/bytes output) 14818/1423344
          14818 packets, 1423344 bytes
          Priority: 200 kbps, burst bytes 5000, b/w exceed drops: 0
        Class-map: VoiceSig (match-all)
          10173 packets, 5305591 bytes
          30 second offered rate 1000 bps, drop rate 0000 bps
          Queueing
          (pkts output/bytes output) 10172/5389661
          bandwidth 100 kbps
          3223078 packets, 313331851 bytes
          30 second offered rate 3000 bps, drop rate 0000 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 0/3/0/3
          (pkts output/bytes output) 3219876/312796275
It looks like the traffic is first queued and shaped then prioritized.
Thanks a lot for your example!
I'll keep you posted of the result.
