QoS on Cisco 7600
wernerleg1
Greetings
I'm marking all ingress traffic with AF21, however, on the egress interface the traffic isn't matching the marking of AF21 I've set on the input policy -seeing all egress traffic in class-default
The ingress and egress interfaces are on the same router.
Ingress interface:
interface GigabitEthernet3/22.10
description labmspe2-int22-10-v3data-speednew-mi | |
encapsulation dot1Q 10
ip vrf forwarding NEW-QOS
ip address 10.10.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
service-policy input 2MB-INPUT-1DATA-P-CHILD-NEW
end
Input policy:
mi-za-lab-mspe2#sh run policy-map 2MB-INPUT-1DATA-P-CHILD-NEW
Building configuration...
Current configuration : 150 bytes
  class class-default
    police cir 2048000 bc 384000 be 768000 conform-action set-dscp-transmit af21 exceed-action set-dscp-transmit af23
Egress interface:
interface GigabitEthernet3/21.10
description labmspe2-int21-10-v3data-speednew-mi | |
encapsulation dot1Q 11
ip address 11.10.1.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
service-policy output 2MB-OUTPUT-3DATA-CHILD-NEW
end
Output policy:
mi-za-lab-mspe2#sh run policy-map 2MB-OUTPUT-3DATA-CHILD-NEW
Current configuration : 356 bytes
  class ALL-VRF-OUTPUT-PLATINUM
    police cir 512000 bc 96000 be 192000 conform-action transmit exceed-action transmit
  class ALL-VRF-OUTPUT-GOLD
  class class-default
end
Class Map match-all ALL-VRF-OUTPUT-PLATINUM (id 3)
   Match   dscp af21 (18)
   Match   dscp af22 (20)
   Match   dscp af23 (22)
   Match access-group name ALL-VRF-OUTPUT-PLATINUM
Policy stats - ingress
mi-za-lab-mspe2#sh policy-map int GigabitEthernet3/22.10
  Service-policy input: 2MB-INPUT-1DATA-P-CHILD-NEW
  Counters last updated 00:00:00 ago
    Class-map: class-default (match-any)
      2294930 packets, 206543700 bytes
      30 second offered rate 684000 bps, drop rate 0000 bps
      Match: any
      police:
          cir 2048000 bps, bc 384000 bytes, be 768000 bytes
        conformed 2294924 packets, 206543160 bytes; actions:
        exceeded 0 packets, 0 bytes; actions:
        violated 0 packets, 0 bytes; actions:
        conformed 684000 bps, exceed 0000 bps, violate 0000 bps
Policy stats - egress
mi-za-lab-mspe2#sh policy-map int GigabitEthernet3/21.10
  Service-policy output: 2MB-OUTPUT-3DATA-CHILD-NEW
    Class-map: ALL-VRF-OUTPUT-PLATINUM (match-all)
      0 packets, 0 bytes
      30 second offered rate 0000 bps, drop rate 0000 bps
      Match:  dscp af21 (18)
      Match:  dscp af22 (20)
      Match:  dscp af23 (22)
      Match: access-group name ALL-VRF-OUTPUT-PLATINUM
      police:
          cir 512000 bps, bc 96000 bytes, be 192000 bytes
        conformed 0 packets, 0 bytes; actions:
          transmit
          transmit
          transmit
        conformed 0000 bps, exceed 0000 bps, violate 0000 bps
    Class-map: ALL-VRF-OUTPUT-GOLD (match-all)
      0 packets, 0 bytes
      Match:  dscp af11 (10)
      Match:  dscp af12 (12)
      Match:  dscp af13 (14)
      police:
          transmit
          transmit
          transmit
      6917038 packets, 622533420 bytes
      30 second offered rate 681000 bps, drop rate 0000 bps
      Match: any
      police:
        conformed 5474588 packets, 492712920 bytes; actions:
          transmit
        exceeded 1115 packets, 100350 bytes; actions:
          transmit
        violated 1441329 packets, 129719610 bytes; actions:
          transmit
        conformed 539000 bps, exceed 0000 bps, violate 142000 bps
Router:
Cisco CISCO7606-S (M8500) processor (revision 1.1) with 3670016K/262144K bytes of memory.
Processor board ID FOX1437H0X8
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.1, (0x80390021)
CORE: E500, Version: 2.2, (0x80210022)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
Last reset from power-on
1 Virtual Ethernet interface
53 Gigabit Ethernet interfaces
12 Ten Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
Linecard: ES+ linecard
IOS: c7600rsp72043-adventerprisek9-mz.122-33.SRE2.bin
dwillie
Impossible for a egress packet to match-all dscp values listed, changed to match any.
dwillie
Hi Darren
Well spotted! I forgot about the default behavior of a class-map.
Many thanks
No problem, glad to help.  That happens more than you would think, we all
do it...
