QoS on IPSec VPN (GRE tunnel) over DSL.
wwilkinson
I am trying to apply QoS to a clients 1800 router at a remote site. They have and IPSec VPN to a central router, with all the branch traffic coming down the VPN. There are 2 VLANs at the remote site, 1 for data and 1 for voice, and both are up and working and data & voice traffic is passing from remote subnets to central site fine. Voice quality suffers during congested periods, hence the need for some QoS (the client assures me that their SP does QoS across the WAN). I have tried to apply CBWFQ to the router, but am unsure of exactly where the policy should be applied, as some documents state physical i/f (ATM0), some the pvc, some the tunnel, and some the BVI i/f! Also a little unsure about whether I should do a nested parent/child policy. Below is the config from the router which did not work when we used WanKiller to overload the link. I have included Telnet traffic for ensuring we could still manage the router while we were using the WanKiller (didn't work!).
class-map match-all Telnet
match protocol telnet
class-map match-all VoIP_Traffic
match access-group name VoIP_Traffic
policy-map VoIP_QOS
class VoIP_Traffic
priority percent 50
class Telnet
bandwidth percent 10
interface Tunnel100
description Link to LAN-VPNCORE-R01
bandwidth 1024
ip unnumbered Loopback0
ip mtu 1410
qos pre-classify
cdp enable
tunnel source x.x.x.x
tunnel destination y.y.y.y
interface ATM0
mtu 1500
no ip address
no atm ilmi-keepalive
pvc 0/101
encapsulation aal5snap
bundle-enable
dsl operating-mode auto
bridge-group 1
bridge-group 1 spanning-disabled
service-policy output VoIP_QOS
interface Vlan1
no ip address
interface Vlan100
ip address 1.1.1.1 255.255.255.240
ip helper-address 1.1.1.12
interface Vlan300
ip address 2.2.2.2 255.255.255.224
ip helper-address 2.2.2.12
standby 0 ip 2.2.2.1
standby 0 priority 105
standby 0 preempt
interface BVI1
ip address x.x.x.192 255.255.240.0
ip access-group 100 out
crypto map INTERNET
ip access-list extended VoIP_Traffic
permit ip 192.168.224.0 0.0.0.31 any
I have done the qos pre-classify on the crypto map as well. Any ideas?
tstanik
Level 5
Level 5
