Qos over DMVPN problem
atiye.bigdeli
Hi Dears
I have a problem with configure qos over dmvpn. I configure dmvpn and Qos but i doesnt work.
the show command "Output QoS service-policy applied: none" display that somthin is wrong.
Core1#sho dmvpn detail
Interface Tunnel0 is up/up, Addr. is 10.199.1.110, VRF ""
Tunnel Src./Dest. addr: 192.168.0.254/MGRE, Tunnel VRF ""
Protocol/Transport: "multi-GRE/IP", Protect ""
Interface State Control: Disabled
Type:Hub, Total NBMA Peers (v4/v6): 1
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb Target Network
1 192.168.0.23 10.199.2.109 UP 00:00:17 D 10.199.2.109/32
NHRP group: Parent
Crypto Session Details:
hub config
interface Tunnel0
bandwidth 128
ip address 10.199.1.110 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication donttell
ip nhrp map multicast dynamic
ip nhrp map group Parent service-policy output Parent
ip nhrp network-id 99
ip tcp adjust-mss 1360
ip ospf network point-to-multipoint
ip ospf cost 12
keepalive 10 2
tunnel source 192.168.0.254
tunnel mode gre multipoint
tunnel key 1000
Spoke
interface Tunnel0
bandwidth 128
ip address 10.199.1.109 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp group Parent
ip nhrp map multicast 10.199.1.110
ip nhrp map 10.199.1.110 192.168.0.254
ip nhrp nhs 10.199.1.110
ip ospf network point-to-point
ip ospf cost 12
keepalive 20 2
tunnel source FastEthernet0/1.300
tunnel destination 192.168.0.254
tunnel key 1000
QOS Config
policy-map Child
class IMP
bandwidth percent 60
class Med
bandwidth percent 30
class MGMT
bandwidth percent 5
policy-map Parent
class class-default
shape average 256000
service-policy Child
debug on spoke
Apr 28 07:25:55.952: NHRP-GROUP: rcvd group name: old 'none' new 'none'
Apr 28 07:25:55.952: NHRP-GROUP: invalid params
Apr 28 07:25:56.952: NHRP-GROUP: added nhrp-group Cisco vendor extn, len 15
Apr 28 07:25:57.808: NHRP-GROUP: added nhrp-group Cisco vendor extn, len 15
on the tunnel, configure 'qos pre-classify', and apply the service policy on the physical interface:
interface Tunnel0
bandwidth 128
no ip redirects
ip mtu 1400
ip ospf cost 12
keepalive 20 2
tunnel key 1000
qos pre-classify
interface Tunnel0
bandwidth 128
no ip redirects
ip mtu 1400
ip ospf cost 12
keepalive 20 2
tunnel key 1000
qos pre-classify
Hi  Georg
Thank you so much dear.
do you mean I create another service policy for the whole BW and apply to fa0/1?
Policy-Map MPLS
Class class-default
Average Rate 64 M
fa0/1
service-policy out MPLS
Thats right?
do I that for both Hub and spoke?
