QoS question
ghassan_81
iam working in a small ISP, well i have 10M as a bandwidth, i devided ADSL users to 5 groups, iam giving each group a spicific amount of the BW, well my problem is when one of the groups is full, and another one is free, the first one can't take from the other, i want to allow a full bw group to take from the other one if and olny if there is a free BW in the other one, can this be done ?
vladrac-ccna
Level 5
Level 5
yes, this can be done with different QOS features.
What are you using at the moment? I believe you are not using a Diff service qos , correct?
CBWFQ is a good option, but it really depends in what type of traffic and the kind of priorization you need.
A good place to start:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt2/qcfconmg.htm
HTH,
if it does, please rate this post.
Vlad
yes correct, iam not using Diff, iam using CBWFQ , but the problem that i think that i need to make conditions like to say if group A has rached its limit and group B still free, then take BW from there and lets keep 0.5M for the free group, actually i asked some seniors and they say this cant be done by cisco router, they said i need another device like Packeteer or BlueCoat to it, but i still that there is a way to do this using cisco routers
assuming you can differentiate the groups by IP address a sample config could look like this:
class-map match-all Group1
match ip address 101
class-map match-all Group2
match ip address 102
policy-map Divide10MB
class Group1
bandwidth percent 45
class Group2
interface Ethernet0
max-reservable 90
service-policy output Divide10MB
access-list 101 permit ip 10.1.0.0 0.0.255.255 any
access-list 102 permit ip 10.2.0.0 0.0.255.255 any
This way you can guarantee at least 45% to each group, but each group also can utilize the full 10MB in case no other traffic exists.
There can be up to 256 (?) classes per policy-map.
Hope this helps! Please rate all posts.
Regards, Martin
I'm quite surprise to hear such afirmation, because I'm still looking for thing CISCO cant do.
But again check the link and you'll see all QOS features cisco IOS can give you,
and again, yes it can be done.
the other reply has some nice line too!
Vlad
