QoS Shaper output is double the shaper rate
russell.sage
Level 3
Level 3
I have an ASR1002 router running 3.16.6S and it has two VRF the default and a second VRF. Both has nested QoS policies the outer to set the CDR the customer has paid for and inner one to prioritise traffic. This post relate to th vrf-lite instance.
The outer policy uses an average shaper
policy-map Outer_XXXXXX_XXX_XXX_CE@25
class class-default
shape average 25000000
Class-map: class-default (match-any)
     258983639 packets, 289802638948 bytes
     5 minute offered rate 6656000 bps, drop rate 0000 bps
     Match: any
     Queueing
     queue limit 104 packets
     (queue depth/total drops/no-buffer drops) 0/238/0
     (pkts output/bytes output) 258983398/289802275125
     shape (average) cir 25000000, bc 100000, be 100000
     target shape rate 25000000
Given the above how is it possible to produce the following output
0 Replies 0
