qos values and input and output queues
sarahr202
Level 5
Level 5
hi every body!
-----f1(SW1)f2--------
Just for illustrative purpose, i am assuming simple values for qos
say qos=1 mean queue 1( frames in this queue will get serviced first)
if sw1 receives a frame with qos=1, sw1 processes the frame provided that qos=1 remain unchanged , will switch 1 place this frame in the queue for outgoing int which will be processsed first?
thanks a lot and have a nice day!
Jon Marshall
Sarah
Assuming you want these packets to be serviced first on egress then you would want to place these packets into the priority queue if the switch port supports a priority queue.
If there is no priority queue then you can map it to a one of the other queues that gets preferential treatment but that is not the same as the priority queue.
Has this answered your question or have i missed the point :)
Jon
Jon Marshall
Sarah
Jon
thanks for your reply Jon!
