Query Regarding classless routing protocol
rawatmohinder
Q:-- Which of the followings are true regarding classless routing protocols.
A.) default-gateway is required.
In explanation it is mentioned that in classless routing protocols default-gateway is not required.
But I think default-gateway is required in both classless or classful routing protocols,bcoz if router receives a request for a network which router don,t know, it will drop the packet, if default-gateway is not mentioned.
Kindly give me feedback regarding this.
Thanks in advance..
Mahi
pkhatri
Level 11
Level 11
Hi Mahi,
You should post all of the options given in the question because I don't believe answer A is correct. Neither classless or classful protocols *need* the default-gateway to function...
Paresh
Hi Paresh,
In question it is asked that what is true about classless routing protocols.
I want to know only that ip-default gateway is required in classless protocols or not.
if router receives a packet for destination about which router don,t know, it will drop the packet. but if u mention that address than router will forward the packet to that address.
Paresh.. do u have any yahoo ID so that i can chat with you.
Mahi
Mahi,
I'd prefer to communicate via the forum where possible but you can always email me - my email address is included in my NetPro profile.
Paresh
