Question about BGP routing
west33637
Hello, I have a question about BGP/OSPF routing. Please see the scenario
example Router A
GI1/1 10.10.2.1/30 -----EBGP link to router B
Router BGP 500
neighbor 10.10.2.2 remote-as 600
example Router B
GI1/1 10.10.2.2/30 -----EBGP link
VLAN 5 192.168.1.6/30
loop0 192.168.1.2
GI1/2 switchport access VLAN 5
Router BGP 600
neighbor 10.10.2.1 remote-as 500 ------  EBGP link to router A
neighbor 192.168.1.1 remote-as 600 ------- IBGP link to router C
Router OSPF 600
passive-interface default
no passive-interface vlan 5
network 192.168.1.2 0.0.0.0 area 0
network 192.168.1.6 0.0.0.0 area 0
Assuming Router B has an IBGP connection to Router C.
example Router C
VLAN 5 192.168.1.5/30
loop0 192.168.1.1
Router BGP 600
neighbor 192.168.1.2 remote-as 600 ------ IBGP link to router B
Router OSPF 600
network 192.168.1.1 0.0.0.0 area 0
network 192.168.1.5 0.0.0.0 area 0
network 192.168.1.9 0.0.0.0 area 0
when I do a show ip route 192.168.1.9 form router A, I get the below output.
sh ip ro 192.168.1.9
Routing entry for 192.168.1.8/30
  Known via "bgp 500", distance 20, metric 0
  Tag 600, type external
  Last update from 10.10.2.2 7w0d ago
  Routing Descriptor Blocks:
  * 10.10.2.2, from 10.10.2.2, 7w0d ago
      Route metric is 0, traffic share count is 1
      AS Hops 1
      Route tag 600
My question is how is it that I have a route entry in Router A known via BGP when BGP is not advertising any networks on any of the routers and OSPF is not being redistributed into BGP?
Note - There is a route-map on Router A that basically says Router A can only advertise the default-route out to router B. Please let me know if anything needs to be clarified. Thanks,
Reza Sharifi
Based on the configs you posted, I see a couple of issues with your design.
1-Network 10.10.2.0 is not being advertised to OSPF on router-B, so if you try to ping 10.10.2.1 or 2 from router-C it will not work.
2-You have configured the IBGP connectivity between Router-B and Router-C with physical IP addressess. although it works, it is not a common practice.
for IBGP you should use the loopback interfaces to peer.
3-Do you have end-to-end IP connectivity in this network?
Reza
Giuseppe Larosa
please post
sh ip bgp 192.168.1.8 taken on RB, the node that has an eBGP session with Ra
Hope to help
Giuseppe
