Question about Dynamic NAT/PAT limits
Chris Brun
Just implemented a straightforward NAT using overload working, however, I have a question about the limits I see on the show ip nat pool command.  For example:
ASR-CO-F8#show ip nat pool name ComcastLR-WL
NAT Pool Statistics
Pool name ComcastLR-WL, id 9
                              Assigned            Available
  Addresses                          1                    1
  UDP Low Ports                    226                  798
  TCP Low Ports                      4                 1020
  UDP High Ports                   629               128393
  TCP High Ports                 52548                76474
(Low ports are less than 1024. High ports are greater than or equal to 1024.)
When I add up the Assigned and Available, I get 129,022.  Is that the absolute limit I can get with a single IP address?  Where did this number come from (I would have expected something like 65,500)?  Can I assume that should I reach this number of assigned NAT's, future NAT requests will fail?
Mohit Sahai
Trust you are doing good.
I think you are hitting the Bug ID CSCuo10862 or CSCum76021
CSCuo10862    XE3.13: show ip nat pool name <pool name> output not proper
CSCum76021    Issue with output for "show ip nat pool name nat-pool"
The entries are indeed wrong and are not expected.
Once you reach the limit of 65535(not sure if it is exact but somewhere near to it), you would start facing logs
%NAT-6-ADDR_ALLOC_FAILURE: Address allocation failed; pool 5 may
be exhausted
Mohit
**Please rate the post if you find this helpfull
