Question about Lawfull Interception...need help !! sip-401, sip-200
Pozitron11
Can anyone tell
me answer to this questions ??
Does SIP-401 module for 12000 series router supports LI IOS software, or  that function can be activated only with sip-600. Can I run Lawfull Interception with sip-401  module on 12406 router ??
and can SIP-200 module for Catalyst 6500 run lawfull interception ios and be used for that purpose ???
This is a bit urgent so I thank you in advance for answers :-)
BR
Dario
Manish Naik
Hello Dario,
          It should be supported on SIP401. howerver there was an issue reported about line card crashes. you may want to check the bug CSCsu12146. Still checking for sip200 support.
Cheers,
Manish.
