question about qos
dave dave
hi! for a p2p lease line of latency below 20ms and bandwidth utlilization of <50% of a 2mb line. do you think it's necessary to have qos configured for voice? Is a seperate vlan required for voice? If qos is required any simple example to follow on this? I'm new to qos. Thanks.
Another question about p2p wan link is that, do you think a wan optimizer is required if traffic is pretty low?
Peter Paluch
Hello Dave,
What kind of leased line is it - MPLS pseudowire, PPP, HDLC, Frame Relay, Ethernet, or a real physical leased line with your encapsulation on it?
Another question is - what is the expected total amount of voice traffic on the line? Can you also specify the voice codec that is being used?
Best regards,
Peter
hi! I think it's a ethernet. Normally what;s the bandwidth used per voice call session? The sites are quite small (20 users max). I would think that the max concurrent call is 70% of that 20 people which is around 14 concurrent calls.
Just curious, What different does it make between the different types of lease lines you mentioned in terms of the needs for qos? Thanks.
Reza Sharifi
Qos is only useful if you deploy it end-to-end.  For voice you usually need to apply qos. (see link below)
Yes, it is a good idea to have a separate vlan/subnet for your phones.
If the traffic is low and you have no issues, you do not need an optimizer
Here is a good doc with QOS design principals and examples:
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind.  Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
QoS necessary for VoIP on a 2 Mbps link, even with <50% utilization? - yes (to protect against transient congestion)
Separate VoIP vlan required? - depends, advisable (protects VoIP devices from unnecessary broadcast)
simple example:
class-map voip
match any (something to match your voip traffic)
policy-map example
class voip
priority percent 35
class class-default
fair-queue
interface serial
service policy example output
WAN optimizer? depends, your "mileage may vary" (with your low utilization and low latency you might not see as much benefit)
