question about regular expressions
west33637
ip as-path access-list 1 permit _\(65301\)
Hello all. Will the above regexp capture all prefixes originating from confederation peer AS 65301?
If not, what is the correct syntax?
Hello ,
yes i did test this , when I test using _\(65301\) or ^\(65301\) or \(65301\) it was only matching prefixes generated by directly connected confederation peer AS ( 65301) .
I understand this happens because escape character (\) is supposed to match special character . and for the matter of fact I also achieved desired results using regular expression 65301\)
Sunil Bhadauria
Sunil Bhadauria
Hello ,
To match prefixes only originating from concerned confederation you can use below regular prefix :
Ip as-path access-list 1 permit  65301\)$
This will get you desired results .
Sunil Bhadauria
Hello Sunil. Thanks for the response. Did you verify this works? I will verify over the weekend in my lab.
Hello ,
Sunil Bhadauria
