Question on route-map match scenarios
blackladyJR
Hi, I am studying for BSCI and can't understand this route-map scenario. I have set up below scenario in my little home lab routers but cannot understand the output.
Router A has 3 interfaces to 3 routers. Rtr A connects to Rtr B with EIGRP 50 via serial 0. Rtr A connects to Rtr C with eigrp 100 via Serial 1. Rtr A connects to Rtr D with OSPF via serial 2.
1. If Rtr A has ospf redistribute into eigrp 100 with a route-map as such:
route-map abc permit 10
match ip address 1
access-list 1 permit 10.1.1.0 0.0.0.255
where 10.1.1.0/24 is the LAN subnet in Rtr D where Rtr D has advertised it within ospf.
So when I goto Rtr C and check my eigrp 100 table, I should expect to see this 10.1.1.0/24 as D EX. But I tested this with my lab routers, but I see from Rtr C 3 D EX routes. There are two LAN subnets in Rtr D. In Rtr C, I see both Rtr D's subnets and the serial interface subnet between A and D also. In Rtr A, there is no redistribute connected at all.
So my question is I have the route-map that suppose only allow 10.1.1.0/24 to redistributed into EIGRP 100, why do I see the other 2 subnets also (the /30 connected between A & D and the other LAN subnet in D).
I even modify the route-map to this:
route-map abc deny 10
match access-list 2
route-map abc permit 20
match access-list 1
access-list 2 permit 172.16.1.0 0.0.0.255
I see from show access-list output that both access lists has a hit, so I expect 172.16.1.0 should be "denied" and won't be redistributed but yet, in Rtr C I still see it as D EX.
I must have misunderstand the use of route-map in redistribution then. My goal is to just redistributed 10.1.1.0 in eigrp 100. I know I can do distribute-list 1 out under eigrp 100 in Rtr A to filter it out. But my goal is to accomplish it via route-map instead of distribute-list.
My other puzzle is I test this same network with the match interface command.
So my route-map now is:
match interface serial 0
!! the serial 0 in Rtr A is the interface to Rtr B which is under eigrp 50. I am applying route-map abc under eigrp 100. My goal is I expect to see no routes being redistribute at all in eigrp 100 when I look at Rtr C. But to my surprise, in Rtr C, I still see all 3 D EX routes. It seems it doesn't matter what match interface I set it to, all 3 routes are shown in Rtr C.
thanks for your patience to read my message and your assistance.
Joyce
Joyce,
The issue is due to CSCee75029. This bugid is causing routes to be redistributed in spite of the route-map. It is fixed in 12.3(10) and up.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCee75029
10 Replies 10
Harold Ritter
Joyce,
It is normal behavior for IOS to redistribute the directly connected subnet between router A and router D since this subnet is owned by ospf and that it will be considered an ospf route from a redistribution point of view.
What is not normal is that your route-map does not filter it out. Can you post the eigrp configuration from router A.
Thanks for your help. Yes if I don't have route-map filtering, I expect to also see the connected route between A & D to be redistributed into EIGRP 100. It's very puzzled of why in Rtr C where I can see all 3 routes belonging to D as I only expect to see 1 route being redistributed.
As for match interface scenario, I purposely choose the interface connecting to RTR B which is not part of EIGRP 100 so I want to test to see if no routes are being redistributed.
Everything looks perfectly fine such as routing table in A is what expected. The only thing that really puzzled is the routing table in C of seeing all 3 routes.
RTRC >sh ip ro
1.0.0.0/24 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, Ethernet1/1
8.0.0.0/24 is subnetted, 1 subnets
C 8.1.1.0 is directly connected, Ethernet1/0
C 192.168.20.0/24 is directly connected, Serial1/0.202
130.1.0.0/24 is subnetted, 1 subnets
D EX 130.1.1.0 [170/40537600] via 192.168.20.2, 00:00:11, Serial1/0.202
D EX 192.165.1.0/24 [170/40537600] via 192.168.20.2, 00:00:11, Serial1/0.202
150.50.0.0/24 is subnetted, 1 subnets
D EX 150.50.50.0 [170/40537600] via 192.168.20.2, 00:00:31, Serial1/0.202
interface Ethernet1/0
ip address 8.1.1.1 255.255.255.0
half-duplex
no keepalive
interface Serial1/0
no ip address
encapsulation frame-relay
clockrate 64000
cdp enable
frame-relay lmi-type cisco
interface Serial1/0.202 point-to-point
ip address 192.168.20.1 255.255.255.0
frame-relay interface-dlci 202
interface Ethernet1/1
ip address 1.1.1.3 255.255.255.0
half-duplex
router eigrp 100
network 8.0.0.0
network 192.168.20.0
no auto-summary
RTRA#sh run
interface Serial0/0
no ip address
clockrate 64000
cdp enable
interface Serial0/0.103 point-to-point
ip address 192.168.20.2 255.255.255.0
frame-relay interface-dlci 103
interface Serial0/0.104 point-to-point
ip address 150.50.50.2 255.255.255.0
frame-relay interface-dlci 104 IETF
interface Serial0/0.201 point-to-point
ip address 172.16.10.2 255.255.255.0
frame-relay interface-dlci 201 IETF
interface Ethernet0/1
ip address 1.1.1.2 255.255.255.0
half-duplex
router eigrp 100
redistribute ospf 1 route-map qwe
! route-map abc provides same result in Rtr C table
default-metric 64 100 255 1 1500
no auto-summary
router eigrp 50
network 172.16.0.0
no auto-summary
router ospf 1
log-adjacency-changes
network 150.50.50.0 0.0.0.255 area 0
access-list 1 permit 130.1.1.0 0.0.0.255
access-list 2 permit 150.50.50.0 0.0.0.255
match ip address 1
match ip address 2
route-map qwe permit 10
match interface Serial0/0.201
RTRA# sh ip ro
C 1.1.1.0 is directly connected, Ethernet0/1
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.10.0 is directly connected, Serial0/0.201
D 8.1.1.0 [90/2195456] via 192.168.20.1, 00:01:31, Serial0/0.103
C 192.168.20.0/24 is directly connected, Serial0/0.103
O IA 130.1.1.0 [110/74] via 150.50.50.1, 00:01:11, Serial0/0.104
10.0.0.0/24 is subnetted, 1 subnets
D 10.1.1.0 [90/2195456] via 172.16.10.1, 00:02:22, Serial0/0.201
O E2 192.165.1.0/24 [110/20] via 150.50.50.1, 00:01:11, Serial0/0.104
C 150.50.50.0 is directly connected, Serial0/0.104
RTRD>sh ip ro
C 130.1.1.0 is directly connected, Ethernet1/0
C 192.165.1.0/24 is directly connected, Ethernet1/2
C 150.50.50.0 is directly connected, Serial0/0.202
Joyce,
What IOS version do you use? Can you try to do a "clear ip ro *" on router A and see if it makes a difference.
Router A 2611 - c2600-j1s3-mz.123-9.bin
Router C 3620 - c3620-ik9o3s6-mz.123-1a.bin
Router D 2613 - c2600-jk8o3s-mz.122-6f.bin
It didn't make a difference after clearing all routes in Router A and C. I even remove the ospf redistribution completely and check to make sure Router C has no D EX routes and then as soon as I put back the redistribute ospf in Router A, then all 3 routes again appear in Router C.
Am I having a wrong understanding about route-map filtering or I have wrong typo in the config?
Is it correct to assume that with the route-map abc, I should only have 150.50.50.0 being redistributed into EIGRP 100? So 192.165.1.0 and 130.1.1.0 both should not be redistributed into EIGRP 100 as 192.165.1.0 gets implicit deny and 130.1.1.0 gets explicit deny?
Also what about the match interface (I never use this before so wasn't sure about this). How should we use match interface command? Reading the definition says it will redistribute matching destination subnet. It's little confused for me. So in my scenario, if I don't have any route-map, all 3 ospf will get redistributed into eigrp 100. So what is the theortical result if I apply match interface route-map qwe to match the interface towards Rtr B? Also if the match interface changes to match the interface towards Rtr C, what is the therotical result? And lastly if the match interface actually change to matching the interface facing back Rtr D, what will happen?
thanks again,
Joyce
Joyce,
I just ran a quick test with 123-9 and it worked like a charm. You understanding of the route-map filtering is correct. Something must be wrong in your configuration.
Could you use route-map abc again and try adding an explicit deny all at the very beginning, such as "route-map abc deny all" and no match statement so that all routes are denied just to see if the routes will be blocked.
Hi Harold,
No luck, I put route-map dfg deny 10 with nothing in match, all 3 routes still show up in Rtr C. I then modify the route-map to:
match ip address 3
access-list 3 permit any
With hits on the access list 3, I still see all 3 routes in Rtr C. When I apply the route-map, I first remove the redistribute completely and check Rtr C to ensure all 3 routes are gone first before re-applying the new route-map in Rtr A.
It's very puzzled why but at least it's good that you have confirmed my route-map filtering understanding of it. I have attached all 4 routers running config and a diagram and their routing tables. Is it really just I am unlucky to have some bad IOS/bug or my config is wrong somewhere?
Since I have a malfunction network so I am not able to test the match interface command to see how it suppose to work, do you mind to let me know what will it suppose to happen in theory if I apply the match interface to match all my 3 interfaces in 3 separate scenarios? I keep reading the definition and now I am confused.
thanks again for all your time.
Joyce
Joyce,
Interesting. Can you post the output for the following commands from RouterA:
show ip eigrp topo 130.1.1.0 255.255.255.0
show ip eigrp topo 192.166.1.0 255.255.255.0
show ip eigrp topo 150.50.50.0 255.255.255.0
Harold,
RTRA#sh ip eigrp topo 192.165.1.0 255.255.255.0
IP-EIGRP (AS 100): Topology entry for 192.165.1.0/24
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 40025600
Routing Descriptor Blocks:
150.50.50.1, from Redistributed, Send flag is 0x0
Composite metric is (40025600/0), Route is External
Vector metric:
Minimum bandwidth is 64 Kbit
Total delay is 1000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
Originating router is 192.168.20.2 (this system)
AS number of route is 1
External protocol is OSPF, external metric is 20
Administrator tag is 0 (0x00000000)
% IP-EIGRP (AS 50): Route not in topology table
RTRA#sh ip eigrp topo 130.1.1.0 255.255.255.0
IP-EIGRP (AS 100): Topology entry for 130.1.1.0/24
Vector metric:
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
External protocol is OSPF, external metric is 74
RTRA#sh ip eigrp topo 150.50.50.0 255.255.255.0
IP-EIGRP (AS 100): Topology entry for 150.50.50.0/24
0.0.0.0, from Redistributed, Send flag is 0x0
Vector metric:
Load is 1/255
Minimum MTU is 1500
Hop count is 0
External data:
External protocol is OSPF, external metric is 0
RTRA#sh ip ro 192.165.1.0
Routing entry for 192.165.1.0/24
Known via "ospf 1", distance 110, metric 20, type extern 2, forward metric 64
Redistributing via eigrp 100
Advertised by eigrp 100 route-map dfg
Last update from 150.50.50.1 on Serial0/0.104, 00:15:28 ago
* 150.50.50.1, from 192.165.1.1, 00:15:28 ago, via Serial0/0.104
Route metric is 20, traffic share count is 1
RTRA#sh ip ro 130.1.1.0
Routing entry for 130.1.1.0/24
Known via "ospf 1", distance 110, metric 74, type inter area
Last update from 150.50.50.1 on Serial0/0.104, 00:15:41 ago
* 150.50.50.1, from 192.165.1.1, 00:15:41 ago, via Serial0/0.104
Route metric is 74, traffic share count is 1
RTRA#sh ip ro 150.50.50.0
Routing entry for 150.50.50.0/24
Known via "connected", distance 0, metric 0 (connected, via interface)
* directly connected, via Serial0/0.104
Route metric is 0, traffic share count is 1
thanks again to help me solving this mystery.
Joyce
Joyce,
Harold,
Thank you so much for all your time to help me. You are absolutely correct, I have upgraded the IOS and wah lah, it works! Now it works on match interface also so I know how it works. I set Rtr B to remove eigrp 50 and enable ospf on it also so I can use match interface to choose either Rtr B or Rtr D routes to be redistributed into eigrp 100 via match interface command.
thank you again for all your help to test run test and search bug for me.
thanks,
Joyce
