Questions about OID ip sla
Translator
Community Manager
Community Manager
Hello! I need a help here
I'm implementing the IP SLA in one infrastructure and it is harder than I imagined.
At the end of each OID it puts a different prefix according to the time that that operation started
is there any way to remove the start time id from this sum?
Giuseppe Larosa
Hello Daniel,
I see in the screenshot the results of an SNMP get or SNMP getbulk on a MIB data structure related to RMON.
the start time id is part of the OID the value is the 0 in the second from the right column in your screenshot.
if you can export the output in CSV format you can then split the ifindex from the starttime they are separated by a  "." .
You can use a script for this.
Hope to help
Giuseppe
Translator
Community Manager
Community Manager
Hello @daniel-jpereira1 ,
 were you able to solve your problem?
Sincerely
