Queue overflow and automated bandwidth adjustment?
twmatthews
Is this possible?
Scenario:  Four QoS classes defined:
     Class A
          bandwidth percent 50
     Class B
          bandwidth percent 10
     Class C
          bandwidth percent 6
     Class Default
          If Class B needs additional b/w (bandwidth), and Class A is currently being used at a fraction of the 50%, do Cisco routers have the capability of configuring for automatic bandwidth adjustments so that Class B "temporarily" increases to a higher b/w percentage (using either resources for Class A or Class Default), and returns that b/w to the original class when Class B no longer needs it or the original class (higher priority) does need it?
Would the "fair-queue" command help with this? (see example)
class A
      fair-queue
class B
      fair-queue
class C
      bandwidth percent 6
      fair-queue
class Default
Thanks for any assistance.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, with your defined policy Class B will "borrow" unused bandwidths from other classes.
No, although FQ offers the advantages of proportional bandwidth sharing between flows within the same class and avoid synchronized tail drop for all the flows within the same class.
And the best way to implement this scenario would  be to use CBWFQ?
Disclaimer
Posting
Unsure I understand your "scenario" as you asked about CBWFQ behavior in one situation.
What do you really want to accomplish?
