1921 Router with 4G LTE interface
daleynicholson
For some reason my cell port on my router will flap as soon as I connect a device and have it connect to the internet.  If there is nothing passing traffic the cell port stays up.  I also have a tunnel that I am sending the traffic through, the tunnel drops as soon as the cell port drops.
5 Replies 5
paolo bevilacqua
Update IOS. If still trouble, contact the TAC.
cbalmer
I'm having the same issue. Sometimes the connection will stay live for a little bit - longest was 90 minutes. But once the flapping starts, it is never ending. I have two routers (2901 and 1921) both experiencing this in two different geographic locations.
I'm uploading a new IOS version to the 1921, but I'm curious if that fixed the issue for you Dailey? If not, did you find a solution? I emailed my Verizon rep already and will contact TAC if it doesn't pan out.
I worked a TAC for it, and it ended up that we were injecting into the cell connection.  After putting an outbound acl on the interface that limited the outbound info to just gre and isakamp info, we were able to make it a stable connection.
Not sure if this helps you, but I would look at seeing if that helps you.
Not quite, but that does mean TAC is the best route. I'll contact them tomorrow (if they're open on Sundays). Thank you for letting me know what you did to get it fixed!
This is the configuration that i got
crypto isakmp policy 2
authentication pre-share
crypto isakmp key cisco123 address 67.21.161.218
crypto ipsec transform-set ASA-IPSEC esp-des esp-sha-hmac
crypto map bars01 1 ipsec-isakmp
description Tunnel toCOrp
set peer 67.21.161.218
set transform-set ASA-IPSEC
set pfs group1
match address 100
interface GigabitEthernet0/0.1
description Legacy vlan
encapsulation dot1Q 1 native
ip address 10.141.116.252 255.255.255.0
standby 0 ip 10.141.116.250
standby 0 priority 105
standby 0 preempt
ip tcp adjust-mss 1395
interface Cellular0/0/0
ip address 166.258.14.27 255.255.255.0
ip virtual-reassembly in
encapsulation slip
dialer in-band
dialer idle-timeout 2147483
dialer string lte
dialer-group 1
async mode interactive
crypto map bars01
ip nat inside source route-map nonat interface Cellular0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
ip route 67.21.161.218 255.255.255.255 Cellular0/0/0
access-list 100 permit ip 10.141.116.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 100 permit ip 10.141.116.0 0.0.0.255 140.140.251.0 0.0.0.255
access-list 100 deny   ip any any
access-list 110 deny   ip 10.141.116.0 0.0.0.255 140.140.251.0 0.0.0.255
access-list 110 deny   ip 10.141.116.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 110 permit ip 10.141.116.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 110
The tunnel connection is establishing correctly but when i change the priority in he hsrp configuration of my gig 0.1 interface to be the active on this router the cellular 0/0/0 interface goes down, by the way this is going to be my redundancy.
Someone can help me?
Thanks a lot
