Quick 1841 routing question
ChuggDogg
Hey guys,
Hoping someone might be able to give me a quick response...
I have a Cisco 1841 partially setup, but I need some quick help regarding port forwarding.
I have a PC running IIS and a website on 10.10.10.2 using port 82.
The Cisco is 10.10.10.1 and the external address is 120.151.XXX.XXX.
I guess all I need to do is create a rule so that when someone tries to access the external IP on port 82 it gets redirected to the test website I have running..
So my question is, does anyone know to do this?
Cheers in advance
ah... if your outside interface is F0/1 then...
ip nat inside source static tcp 10.10.10.2 82 interface FastEthernet0/1 82
Daniel Bethke
I think you're looking for something like this:
ip nat inside source static tcp 10.10.10.2 82 interface FastEthernet0/0 82
Probably should of included my current config, so here it is
version 12.4
hostname router
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$36Nq$OXnnHoXFqH5JxfAItZN.K.
enable password xxxxxxx
no aaa new-model
ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
archive
log config;
  hidekeys
policy-map shape-all
class class-default
  shape average 9300000
description $ETH-LAN$
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
no mop enabled
ip address 120.xxxx.xxx.10 255.255.255.252
ip nat outside
speed auto
full-duplex
no mop enabled
service-policy output shape-all
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 120.xxx.xxx.9 permanent
ip route 10.1.1.0 255.255.255.0 FastEthernet0/1
ip route 120.xxx.xxx.8 255.255.255.252 FastEthernet0/0
ip http server
ip nat inside source list 2 interface FastEthernet0/1 overload
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxx
login
scheduler allocate 20000 1000
end
