"address-family ipv4 unicast" is necessary?
wfqk
Level 5
Level 5
Hi The below is bgp configuration in Nexus7k. Do you think it is necessary to use address-family ipv4 unicast? The address-family ipv4 has three choices. The unicast is one of the three. unicast is considered as by default. I mean even if we do not use it, it already is unicast. Any one can explain it? Thank you
router bgp 6112
  log-neighbor-changes
  vrf ABC
    local-as 65111
Philip D'Ath
I think it puts in "address-family ipv4 unicast" anyway, so I think it is a moot point.
nspasov
You can remove this command but then you would have to manually "activate" neighbors for the ipv4 address family. There is a very good post about this in the community:
https://supportforums.cisco.com/discussion/11476526/when-use-bgp-address-family
I hope this helps!
Thank you for rating helpful posts!
