QOS ON PPPOE
kennedymacharia
I need help I am trying to configure QOS for my video conference I have three sites two of them are on normal Ethernet and one is on PPPOE the two sites on Ethernet are working fine but the one on PPPOE seems not to work thus degrading video .I have attached my config any help will be highly appreciated.
Amit Goyal
Below is the QOS config which is applied on Dialer1
class-map match-all Video_Conference
match access-group 108
policy-map QoS-Policy
class Video_Conference
  bandwidth percent 99
1. Please confirm the bandwidth available on dialer 1 (show int d1). Is this expected or you see some difference?
2. show policy-map int d1 (to check any drops in QOS)
-Amit
Hi Amit,
Thank you for the reply. The bandwidth from the isp is 12 mb. I have attached the output.how can I verify the QOS.
I don't see any drop in QoS so I don't think Video Conferencing traffic is suffering from the congestion. Still you can try and configure "bandwidth" of 12 Mb on dialer interface and check if it helps.
-Amit
