"ip nat inside source static network" with route-map
zhenxu_zj
How would you use "ip nat inside source static network" with an route-map? The specific situation is:
Inside LAN: 192.168.1.0/24
The inside LAN address should be NAT'd to 172.30.11.0/24 only if the traffic is going to 172.30.10.0/24.
I have tried the following with no luck:
ip access-list extended nat-acl
permit ip 192.168.1.0 0.0.0.255 172.30.10.0 0.0.0.255
route-map nat-map permit 10
match ip addres nat-acl
ip nat inside source static network 192.168.1.0 172.30.11.0 /24 route-map nat-map
However, if the route-map is not specified in the "ip nat inside source static network", the translation works for all traffic.
On the other side, I was able to set this up with "ip nat pool" and route-map.
ip nat inside source list nat-acl route-map nat-map pool nat-pool
ip nat pool nat-pool 172.30.11.0 172.30.11.255 netmask 255.255.255.0 type match-host
Any advice is appreciated!
Thanks!
6 Replies 6
Jon Marshall
Zhen
The way you have set it up is the correct way although if you are not matching on something other than source & destination IP addresses you could just as easily have done
ip nat inside source list nat-acl pool nat-pool
ie. you only need a route-map if you want to match on other things such as next-hop ip address/output interface etc.
You would not use the static statement -
because you are dynamically Natting source IP addresses not statically mapping them.
Hope this makes sense.
Jon
Indeed, I do need static one-to-one mapping so that outside host (from 172.30.10.0/24) can access the internal host (182.168.1.0/24) via the nat'd outside address (172.30.11.0/24).
Zhen
Sorry i didn't explain it properly. Even though you want a one to one mapping you are still dynamically allocating them as needed ie. until traffic passes through the router the NAT translation is not there and after a period of inactivity the translation is removed.
Jon
Hello Jon and Zhenxu
I will revive this thread because I have similar if not the same problem. (policy NAT on IOS)
Inside LAN: 10.136.96.0/20
The inside LAN address should be NAT'd to 10.108.96.0/20 ONLY if the traffic is going to 10.203.208.0/24.
But I need it to work both ways.
I am able to make it work with sessions initiated in one direction (from 10.136.96.x to 10.203.208.y), but not both directions. ( 10.203.208.0/24 to 10.108.96.0/20 as well)
ip access-list extended NAT-A-B
permit ip 10.136.96.0 0.0.15.255 10.203.208.0 0.0.0.255
route-map rm-nat permit 10 match ip address NAT-A-B
ip nat pool net-x 10.108.96.0 10.108.111.255 prefix-length 20 type match-host
ip nat inside source route-map rm-nat pool net-x
I tried to do it with ACLs and it worked the same way(one way).
I tried to add ip nat inside destination with similar logic, but that caused the condition to be neglected
and all traffic from 10.136.96.0/20 ended up translated.
I tried to use reversible option on top of using route-map scenario, but that only creates general entry in the NAT table for specific entries created in the first step.
so e.g. if I do ping from SA:10.136.96.8 to DA:10.203.208.1, the router correctly translates it to SA:10.108.96.8 DA:10.203.208.1 and I am able to ping in the opposite direction - from 10.203.208.1 to 10.108.96.8.
But I can not initiate session from 10.203.208.1 to anything else than 10.108.96.8.
So "reversible" is not ment as remedy for this situation.
I do not have option "route-map" available in "ip nat static network A B /X"which would be the simpliest scenario if it was working.
please help on how to do this if possible.
Thank you
Leo
Hi Leo,
The reverse ping from 10.203.208.1 to 10.108.96.8 was working because it was already presented in NAT translation table due to your initial ping (SA:10.136.96.8 to DA:10.203.208.1) hits the routemap and trigerred NAT.
The reason it was not pinging from 10.203.208.1 to anything else is that, there is no translation for other destination apart from 10.108.96.8 in NAT table so far.
Note: For dynamic NAT inside, the traffic should be initiated from inside to outside. Not from outside to inside.
Thank you for your reply.
I probably wrote the question in a wrong way.
The question is how to do it, so I can initiate traffic from outside and
have the same behaviour.
Thank you
