"ip pim sparse-mode" under interface can work in ASR9K?
wfqk
Level 5
Level 5
Hi Do you think command "ip pim sparse-mode" can work in ASR9K? I typed it under interface, but it cannot work. Anyone can give some suggestions? Thank you
5 Replies 5
Reza Sharifi
When you say "I typed it under interface, but it cannot work." what do you mean? What is the error message you get?
Also, spars-mode should work fine on the 9k.
More info here:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/multicast/configuration/guide/b_mcast_cg42asr9k/b_mcast_cg42asr9k_chapter_01.html#con_1091398
Thank you for your reply. and sorry for that unclear expression.
Command "ip pim sparse-mode" cannot be entered under interface mode. Of course, ASR9K can support Multicast, but i think there might be another different syntax command for ASR9K. I could not find it in Cisco document.
Have you enabled multicast routing and than enable multicast for all interfaces before entering
"ip pim sparse-mode" under the interface?
Have a look at this doc on how to enable it for interfaces.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/multicast/configuration/guide/b_mcast_cg42asr9k/b_mcast_cg42asr9k_chapter_01.html#con_1091781
Yes, I did it as the below, but I still cannot enter the command under interface
6W(config)#multicast-routing
6W(config-mcast)#ipv4 interface all enable
6W(config-mcast)#exit
6W(config)#commit
Hello
Have you enabled globally multicast routing first?
res
Paul
Kind Regards
Paul
