Can't access web server located in DMZ from inside network
clarenceclay
Hi Cisco expert,
Below is my ASA running config. I'm able to ping the host 10.1.100.1 in DMZ from inside host 10.10.1.1 but unable to browse or view its web content. Could anybody enlighten me what gone wrong.
Thank you.
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.252
interface Vlan2
nameif outside
security-level 0
ip address 219.93.30.130 255.255.255.224
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address 10.1.100.14 255.255.255.240
route outside 0.0.0.0 0.0.0.0 219.93.30.129 1
route inside 192.168.2.0 255.255.255.252 192.168.1.2 1
route inside 10.10.1.0 255.255.255.0 192.168.2.2 1
access-list DMZ extended permit tcp 10.10.1.0 255.255.255.0 host 10.1.100.1 eq www
access-group DMZ in interface dmz
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
telnet timeout 5
ssh timeout 5
dhcpd enable inside
dhcpd auto_config outside
Dennis Mink
the thing is,  you access list is applied to the DMZ interface inbound,  that will never get hit on port 80 (www).  the return traffic from 10.1.100.1 to 10.10.10.0/24 will never use port 80 in response.
that access list seems to need to applied to the inside interface
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
