Hi, there,
I did used 'show ip cache flow' to see the ip packet transaction on the router to see the source and destination IP and port in Hex.
but, I don't know how to activate this function on ASR router. when I tried to issue the command 'show ip cache flow', nothing output.
Do you have any idea what I need to check? netflow is already enabled on the router.
as I remembered, we could see the packet flow when we just enabled the netfow on router.
