R1 cannot ping r4 yet BGP routes are propegated
hfakoor222
R2:
R2 can ping R4 as it is direct connected
R2#ping 24.0.0.4
Sending 5, 100-byte ICMP Echos to 24.0.0.4, timeout is 2 seconds:
R1 cannot Pinfg R4
Success rate is 0 percent (0/5)
R1#
Configs:
hostname R1
no ip domain lookup
interface Serial0/0
ip address 10.1.12.1 255.255.255.0
clock rate 2000000
interface Serial1/0
ip address 10.1.13.1 255.255.255.0
serial restart-delay 0
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.1.12.1 0.0.0.0 area 0
network 10.1.13.1 0.0.0.0 area 0
router bgp 100
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 2.2.2.2 remote-as 100
neighbor 3.3.3.3 remote-as 100
neighbor 10.1.12.2 remote-as 100
neighbor 10.1.13.3 remote-as 100
address-family ipv4
neighbor 2.2.2.2 activate
neighbor 3.3.3.3 activate
neighbor 10.1.12.2 activate
neighbor 10.1.13.3 activate
no auto-summary
no synchronization
network 10.1.12.0 mask 255.255.255.0
network 10.1.13.0 mask 255.255.255.0
exit-address-family
Router 2
interface Serial0/0
ip address 10.1.12.2 255.255.255.0
clock rate 2000000
interface Serial1/1
ip address 10.1.23.2 255.255.255.0
interface Serial1/2
ip address 24.0.0.2 255.255.255.0
interface Serial1/3
no ip address
shutdown
router bgp 100
bgp router-id 2.2.2.2
neighbor 1.1.1.1 remote-as 100
neighbor 4.4.4.4 remote-as 400
neighbor 4.4.4.4 ebgp-multihop 2
neighbor 10.1.12.1 remote-as 100
neighbor 10.1.23.3 remote-as 100
neighbor 24.0.0.4 remote-as 400
neighbor 24.0.0.4 ebgp-multihop 2
address-family ipv4
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 next-hop-self
neighbor 4.4.4.4 activate
neighbor 10.1.12.1 activate
neighbor 10.1.23.3 activate
neighbor 24.0.0.4 activate
no auto-summary
no synchronization
network 10.1.23.0 mask 255.255.25.0
exit-address-family
Router 4
speed auto
interface Serial0/0
ip address 24.0.0.4 255.255.255.0
clock rate 2000000
interface Serial1/0
ip address 46.0.0.4 255.255.255.0
router bgp 400
bgp router-id 4.4.4.4
neighbor 6.6.6.6 remote-as 600
neighbor 24.0.0.2 remote-as 100
neighbor 46.0.0.6 remote-as 600
address-family ipv4
redistribute connected
neighbor 6.6.6.6 activate
neighbor 24.0.0.2 activate
neighbor 46.0.0.6 activate
no auto-summary
no synchronization
network 24.0.0.0 mask 255.255.255.0
network 46.0.0.0 mask 255.255.255.0
exit-address-family
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
any suggestions?
Hello
R2
router bgp 100
neighbor 10.1.12.1 next-hop-self
neighbor 10.1.23.3 next-hop-self
Clear ip bgp * soft in
Clear ip bgp * soft out
Kind Regards
Paul
8 Replies 8
Simply R1 not know next-hop 24.0.0.2
1-config static route for only 240.0.0.2 toward R2
2-config IGP and advertise link between Router only
3- config R2 as @paul driver  suggest to use next-hop self
Hello
R2
router bgp 100
Kind Regards
Paul
It works
hfakoor222
I have another issue
I cannot get R2 to ping R6
 R4#  sh running-conf
 router bgp 400
address-family ipv4
neighbor 24.0.0.2 next-hop-self
neighbor 46.0.0.6 next-hop-self
no auto-summary
no synchronization
exit-address-family
interface Serial0/0
clock rate 2000000
interface Serial1/0
R4 has AS 100 routes in BGP routing table
yet R6 does not
R6 Configuration:
interface Loopback0
ip address 6.0.0.0 255.255.255.255
interface Loopback1
ip address 6.0.1.0 255.255.255.255
interface Loopback2
ip address 6.0.2.0 255.255.255.255
interface Serial0/0
ip address 67.0.0.6 255.255.255.0
clock rate 2000000
interface Serial1/0
ip address 46.0.0.6 255.255.255.0
router bgp 600
bgp router-id 6.6.6.6
neighbor 46.0.0.4 remote-as 400
neighbor 46.0.0.4 update-source Loopback0
neighbor 67.0.0.7 remote-as 700
address-family ipv4
neighbor 46.0.0.4 activate
neighbor 67.0.0.7 activate
no auto-summary
no synchronization
network 6.0.0.0 mask 255.255.255.0
network 6.0.1.0 mask 255.255.255.0
network 6.0.2.0 mask 255.255.255.0
exit-address-family
ip forward-protocol nd
& R2
Has 46.0.0.0 network in its BGP routing table
In this situation am I supposed to create a static route from r4 to r6?
Would someone show me how?
This seems like a lot of nuance if someone were to be working with BGP in the field to keep a track of all of this
router bgp 400
Two peer same AS 600 and I think it same peer?
And as i mention before,
Between bgp peer
Static route "only for loopback"
Igp "only link between routers and loopback"
Next hop only between ibgp
hfakoor222
I created a static route to the 46.0.0.0 network from R2 and cannot still ping 46.0.0.6 at Router R6
interface Serial1/1
router bgp 100
address-family ipv4
no auto-summary
no synchronization
network 10.1.23.0 mask 255.255.255.0
exit-address-family
ip route 46.0.0.0 255.255.255.0 24.0.0.4
any suggestions on moving forward?
can you share the config of R1,R2,R4,R6.
Friend I will make it easy for you
you topology divide it in two layer
first layer is contain
link between Router & Loopback "only loopback use for update-source of BGP"
you must see all link and loopback from any router in this layer EXCEPT in iBGP in which you can use next-hop self.
second layer
config the BGP and advertise all network loopback "not use for update-srouce of BGP"
what make route appear but not ping ??
do show ip bgp
see this route what it is next-hop <<<< are this next-hop reach via layer one
How I check layer one ? do show ip route any subnet not "learn form BGP 'B'" is use for layer one.
if yes then you can ping
if not then you need to reconfig layer one to make next-hop reachable.
How I do last point ??
1- using static route
2-IGP
3- next-hop self "between iBGP only"<<< how next-hop effect layer one ?? it change the next-hop to one appear in layer one
