R1841 does not shows static routes configuration
Abhishek Nagar
I have the cisco 1841, where I am trying to put the static routes on it,
it does execute the route commnad but does not show the static route
can you please help on this, what can be the problem?
Below is the out come
lab_router1(config)#ip route 192.168.1.24 255.255.255.248 fas 0/0
lab_router1(config)#ip route 192.168.1.32 255.255.255.248 fas 0/1
lab_router1(config)#exit
lab_router1#sh ip route stati
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     192.168.1.0/29 is subnetted, 2 subnets
C       192.168.1.32 is directly connected, FastEthernet0/1
C       192.168.1.24 is directly connected, FastEthernet0/0
18 Replies 18
Hi Richard
the ping on the pc is working fine
i have off the fire wall
Abhishek
To be sure that I am understanding the issue correctly, am I correct in understanding that the router is able to ping both of the PCs but the PCs are not able to ping each other?
If that is the case then I would like to see the output of a test where each PC attempts to ping all of the interfaces on the router (each PC pings to 192.168.1.25, to 192.168.1.33, and to10.233.13.9.
Rick
Rick
from pc 0, 192.168.1.26, ping to
C:\Users\Abhi>ping 192.168.1.25
Pinging 192.168.1.25 with 32 bytes of data:
Reply from 192.168.1.25: bytes=32 time=1ms TTL=255
Reply from 192.168.1.25: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.1.25:
C:\Users\Abhi>ping 192.168.1.33
Pinging 192.168.1.33 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.33:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Please do not include the
10.233.13.9., as of now, as my E1 is not up currently, so no point , but still copying it
C:\Users\Abhi>ping 10.233.13.9
Pinging 10.233.13.9 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.233.13.9:
but , from Pc1
I am actually able to reach 192.168.1.25, and ofcourse 192.168.1.33 (this is may be because, I have turn off fw, and restart the machine during our conversation), this machine is win xp,
let me do same thing with pc0, which is win 7, (turn off fw and restart pc)
hi all
the problem was with the pc0, fw, which is on Win7,
i have replaced it with another xp mahcine, and now everything is fine
thanks for all quick support
