Radio LTE Technology Selected = EVDO
ElPadre
I am configuring a router (1941 ISR) for 4G/LTE services.  I have verified through carrier (Verizon) that the SIM is provisioned and I have great coverage in my area.  However, the EHWIC-4G-LTE-V card is only receiving EVDO coverage.  I have tried to manually go set the radio mode from: LTE Technology Preference = AUTO to: LTE Technology Preference = LTE.  I shut down the interface (cell 0/0/0) first and delivered the command cell 0/0/0 lte tech lte.  I saved the configuration and turned the interface up again.  After allowing the interface to come back up it radio goes back to LTE Technology Preference = AUTO  & LTE Technology Selected = eHRPD(EVDO).
Any thoughts/feedback will help!
I think you have to enable the modem first to scan for different technologies by using the command below:
1941#cellular 0/0/0 lte technology
I have tried that.  It switches over to the LTE technology for a second but shortly after it reverts back to Auto and EVDO.  I filed a TAC and it was the card that was determined to be bad.  Thanks for the response though!
