rate-limit and service-policy commands on same interface
turklandbank
For a reason I need to apply rate-limit output AND service-policy output command to the same GRE tunnel interface.
I wonder which one applies first...
Thanks in advance.
why don't you put a policer in the same service policy ?
IOS has some limitations with QoS on GRE tunnel interfaces.
Only 1 user-defined class as child service policy  which is  voice obviously can be defined and other traffic goes to parent default class.
What I need is to use service policy that has at least 2 user defined (acl based) classes of traffic + default class on a GRE tunnel interface.
Using the main interface of GRE tunnel for the service-policy output command and using qos pre-classify command under the tunnel interface,  does not count here. Because it has several GRE tunnels under itself.
I am open to suggestions.
Regards.
Joseph W. Doherty
I recall(?) the interface rate-limit takes precedence (but don't quote me). (Further recall, somewhere Cisco has a paper that documents command precedence.)
I also recall(?) on newer IOS versions, the interface commands for shape and/or rate-limit might no longer be available as either can be done via a service policy.
thanks for the answer.
