dmvpn / mGRE qos setting
perkin
have a question regarding the QoS bandwidth for the DMVPN /mGRE interface
simple configuration
interface GigabitEthernet0/0/0
description ISP_FACING
bandwidth 100000
interface Tunnel11
description PRIMARY_TUNNEL
bandwidth 100000
nhrp map group QOS_GROUP service-policy output MAIN_QOS_POLICY
qos pre-classify
bfd template BFD_TUNNEL
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
policy-map SUB_QOS_POLICY
class CM_VOICE-TRAFFIC
priority percent 20
class CM_BUSINESS-CRITICAL-TRAFFIC
bandwidth percent 20
random-detect
queue-limit 1024 packets
class CM_STANDARD-TRAFFIC
bandwidth percent 50
random-detect
class class-default
policy-map MAIN_QOS_POLICY
class class-default
shape average percent 100
service-policy SUB_QOS_POLICY
the question is
I set up full mesh nhrp
with this interface, I am connected to 5 spoke (or hub since I do full mesh nhrp configuration) , and they are in difference actual thoughput (e.g. some are 20 Mbps links some are 50 Mbps links)
since QoS for multipoint connection and the QoS policy are per-endpoint, will QoS policy think I have 100Mbps x 5 bandwidth?
can I set up a QoS Policy which will limit my egress as 100Mbps?
Many thanks it was my mistake coz the first one I can’t found after I created and then I found a Cisco pdf as the example to show my concern so I created another one
I will like this to the new thread as solution
Giuseppe Larosa
Hello Perkin,
you have opened also another trhead on this same argument.
Follow the answers provided there.
You need to use two different NHRP groups one for the spokes with 50 Mbps link and one for the spokes  with 20 Mbps links.
The two parent policy are shaper that limit to 50 Mbps and to 20 Mbps respectively.
Do not use a line like the following in the parent shaper as one instance of it is created for each spoke in the group
use
shape average 50000000
and
shape average 20000000
Hope to help
Giuseppe
