rate limit in an interface with secondary IPs
egitonga1978
I have confugure secondary IPs in a cisco router interface Ethernet/IEEE 802.3 interface and I wish to configure different bandwidth to each IP, how do I use rate limit to do this ?
You can use rate-limit committed access rate (CAR) which access-group sentence , Applies this CAR traffic policy to the specified access list.
Example:
int FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip address 192.168.1.1 255.255.255.0 secondary
rate-limit input access-group 100 10000000 80000 80000 conform-action continue exceed-action drop
rate-limit input access-group 110 448000 8000 32000 conform-action transmit exceed-action drop
access-list 100 permit 192.168.0.0 0.0.0.255
access-list 110 permit 192.168.0.0 0.0.0.255
Raul
rajib_das
can u pls mention the router model ?
rajib
Below is the show ver output of my cisco router:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(46), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Thu 26-Apr-07 18:06 by pwade
Image text-base: 0x60008930, data-base: 0x61140560
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
System image file is "flash:c3640-is-mz.122-46.bin"
cisco 3640 (R4700) processor (revision 0x00) with 60416K/5120K bytes of memory.
Processor board ID 17148101
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
1 Ethernet/IEEE 802.3 interface(s)
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Elias
Example:
int FastEthernet0/0
Raul
