rate-limit not working
chetan Hedaoo
I am bit confused that how rate limit works,Below is my config ,  I want to limit the traffic on Fa0/0 intreface comming from 50.50.50.50/32 to 100.100.100.100/32 to 2 MB if traffic exceeds it should drop.Pls help to solve.
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.252
rate-limit output access-group 101 2000000 25000 50000 conform-action transmit exceed-action drop
rate-limit input access-group 101 2000000 25000 50000 conform-action transmit exceed-action drop
duplex auto
speed auto
end
access-list 101 permit ip host 50.50.50.50 host 100.100.100.100 log
smehrnia
Level 7
Level 7
is CEF enabled on ur device? whats ur chasis?
and one more question, in which direction are you expecting 50.50.50.50 to come in? you setup ONE source for both input and output !
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Thanks Soroush,
This is im tring on Dynamips(3745) but i want to do it in live productioin with cisco-1841.
I have tried after disabling CEF & removing input rate limit but no luck.
My first confusion is in rate limit syntax as i want to put the CAR for specific IP address to 2 MB with burst size of 2.5 MB , it should transmit the packet if it reaches to 2.25 MB & it should drop if it reaches to 2.5 MB thus pls chk my below syntax if it is correct.
Hi chetan,
where is the full policy?
This i believe to be a good starti point:
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qccar.html
and this:
http://www.cisco.com/en/US/docs/ios/11_1/feature/guide/CAR.html
I would probably check again your ACL.
Alessio
Thanks Alessio,
I am not using any policing and shapping for traffic but I just want to put CAR to 2 mb on ip 50.50.50.50 while accessing data from server 100.100.100.100.
Thus I am tring to configure rate limit.
SO kindly help to understand what is averge rate, normal burst & exceeed burst if i want to put CAR of 2 mb to 2.5 mb.
