Rate Limit on Gi interface
rcctong
I would like ot know how to rate limit the incoming traffic on a GigE interface.
kradjesh13
Raymond,
You can rate-limit an interface using couple of ways.
1. Directly applying rate-limit command on the interface, as shown below
interface GigabitEthernet0/1.100
description Rate Limiting to 2M
ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx
rate-limit output 2000000 62500 62500 conform-action transmit exceed-action drop
2. You can use a class-map and policy-map for rate-limiting an interface which is called modular QOS. This may be considered as a powerful methord since, the traffic can be differenciated.
class-map match-all captureall
match any
policy-map Ratelimiting
class captureall
police 2000000 62500 62500 conform-action transmit exceed-action drop
ip address XXX.XXX.XXX.XXX XXX.XXX.XXX.XXX
service-policy output Ratelimiting
Hope this will help you
Rajesh
Rajesh , I think you have given the rate-limit for Output traffic . For rate-limiting incoming traffic , just change the "output" to "input" in both the commands.
Hope this helps
regards
vanesh k
I am sorry, i thought he asked for output traffic.
Ramond, as mentioned by Vansesh need to change the output to input and that should be working fine.
Rajesh
