Rate-Limit
lovefunlove
Hello Guys
I have Cisco 1721 Router and have one serial and one Ethernet port. when i configure following commands for rate limit by trying on both the interface ( Serial and Ethernet) one by one
rate-limit input access-group 110 25000 2000 2000 conform-action drop exceed-action drop
rate-limit output access-group 110 25000 2000 2000 conform-action drop exceed-action drop
and
access-list 110 permit tcp any any.
when i try to do FTP from my lan PC the connection is not establishing.
When i do ftp without rate limit command it is hapenning.
Can you guys help me out.
MAX
Hello Max,
you are rate-limiting all TCP traffic, possibly your FTP gets starved out, since you are limiting the traffic to only 25000 bits per second. Try to cnfigure the access list as:
access-list 110 permit tcp any any eq ftp
or increase the average rate (to e.g. 800000, with burst normal and burst-max set to 1600 and 2400, respectively).
HTH,
GP
a_w_ghaffar
please check your rate-limit configuration , the conform-action should not be "DROP" it should be " CONTINUE"
regards
AWG
